Community Member
GRE mtu size
while configuring GRE on 6509 we are not able to enter below command on the interface can you please advise on 6509 image 15.1
6509(config-if)# ip mtu 1400
6509(config-if)# ip tcp adjust-mss 1360
thanks for help
1 REPLY
VIP Purple
Re: GRE mtu size
Hi Amit,
May be u r hitting a bug.
Check this bug : CSCtq09372
Check this bug here: https://tools.cisco.com/bugsearch/bug/CSCtq09372
Hope it helps.
162
