09-20-2010 06:35 AM - edited 03-06-2019 01:04 PM
HI ALL,
I AM FACING PROBLEM WITH GRE TUNNEL FLAPPING BUT THE OUTPUT (SHOW LOGGS ONLY DISPLAY ) LINE PROTOCOL FLAPING AND SUDDENLY IT GETS CONSTANT NOW EVERYTHING IS FINE BUT THIS IS THE SECOND TIME WE R FACING THE SAME ISSUE..
ALSO THE FRAGMENT TABLE AND BGP RELATED LOGS APPEARED BUT NOT ON THE SAME DAY AS THE TUNNEL WAS DOWN..
KEEP ALIVE AND STATIC ROUTE GIVEN ...ALSO NO PROBLEM WITH SERVICE PROVIDER LINK FOUND...
ALSO SEE THE SHOW TECH UPLOADED IN THE ATTACHMENT!!
PLZ SUGGEST !!!!!!
IP_VFR-4-FRAG_TABLE_OVERFLOW: FastEthernet0/2/0: the fragment table has reached its maximum threshold 16
Sep 8 18:17:16.229 IST: %IP_VFR-4-FRAG_TABLE_OVERFLOW: FastEthernet0/2/0: the fragment table has reached its maximum threshold 16
Sep 10 02:36:49.258 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to down
Sep 10 02:36:59.258 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to up
Sep 10 02:39:04.259 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to down
Sep 10 02:40:04.260 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to up
Sep 10 02:40:19.260 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to down
Sep 10 02:40:24.260 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to up
Sep 10 02:43:39.261 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to down
Sep 10 02:43:54.262 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to up
Sep 10 02:44:19.262 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to down
Sep 10 02:44:29.262 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to up
Sep 10 02:47:34.280 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to down
Sep 10 02:47:54.280 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to up
Sep 10 02:51:44.282 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to down
Sep 10 02:52:04.282 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to up
Sep 10 02:53:14.283 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to down
Sep 10 02:53:19.283 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to up
Sep 10 02:58:44.285 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to down
Sep 10 02:58:49.285 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to up
Sep 10 03:00:39.286 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to down
Sep 10 03:00:49.287 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to up
Sep 10 03:01:04.287 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to down
Sep 10 03:01:34.287 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to up
Sep 10 03:02:44.288 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to down
Sep 10 03:03:04.288 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to up
Sep 10 03:03:19.288 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to down
Sep 10 03:03:24.288 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to up
Sep 10 03:11:19.332 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to down
Sep 10 03:11:49.333 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to up
Sep 10 03:16:09.343 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to down
Sep 10 03:16:39.343 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to up
Sep 10 03:41:39.365 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to down
Sep 10 03:41:44.365 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to up
Sep 10 04:04:59.407 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to down
Sep 10 04:05:09.407 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to up
Sep 10 04:10:54.431 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to down
Sep 10 04:10:59.431 IST: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnel10, changed state to up
Sep 11 10:42:41.181 IST: %BGP-5-ADJCHANGE: neighbor 10.254.242.225 Down BGP Notification sent
Sep 11 10:42:41.181 IST: %BGP-3-NOTIFICATION: sent to neighbor 10.254.242.225 4/0 (hold time expired) 0 bytes
Sep 11 10:43:51.698 IST: %PIM-5-NBRCHG: neighbor 10.254.242.225 DOWN on interface FastEthernet0/3/0 non DR
