Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
gui interface
how do i access gui interface of cisco6509 layer 3 switch
Re: gui interface
HI Prakash, [Pls Rate if HELPS]
>>Enable the HTTP server. For example:
(config)# ip http server
>>Configure the authentication method for the HTTP server. For example, if your authentication method is local:
(config)# ip http authentication local
If you do not configure an authentication method, the HTTP server uses the enable password for authentication by default. You can use RADIUS for HTTP server authentication. For example:
(config)# aaa new-model
(config)# aaa authentication login default group radius
(config)# aaa authorization exec default group radius
(config)# ip http authentication aaa
Pls Rate if HELPS
Best Regards,
Guru Prasad R
Re: gui interface
Hi Guruprasad,
I have a problem i Have configured the 6509 switch for one of the port as switchport with ip address which in turn is connected to firewall but unable to ping gateway and its own interface it give request time out do i need to configure any other settings it is a 6509 switch with sup32 engine and 48port10/100
module and servers are directly terminating to the 48 port module
Re: gui interface
Hi ,
I have used 6509 switch for the server farm i have connected one of the port as trunk port with ip address which in turn is connected to firewall but i am unable to ping gateway i,e,ip address of firewall as well as trunk port of the core switch from any of the port on core switch even after configuring as access port it gives request time out do i need to configure any other settings it is a 6509 switch with sup32 engine and 48port10/100
228
