Webcast-Catalyst9k
GVRP not working on Cisco SG300-28
I have three Cisco SG300-28 switches. I setup a test lab environment with a core (server) switch in Layer 3 mode and the rest are (clients) in Layer 2 mode. As I understand, these switches doesn't support VTP, only GVRP. And GVRP works the same with VTP. Whenever you create VLANs on the core or main switch, other switches will learn from the core switch and no VLAN creation for the client switches will be made. (Hope I got it right. I guess GVRP is more complicated than VTP).
GOAL: Obviously, I want to use GVRP to create VLANs on the main switch so that I won't be doing it all over on the other switches.
The following is my (so far) configuration through CLI only:
I haven't use the web GUI. My SW version is 1.1.2.0.
1. I already enabled the GVRP globally.
2. I configured GE 12 & GE 24 as TRUNK ports for the core switch that connects both switches, I also configured GE 12 ports for both the client switches. All other ports are in ACCESS mode. (I am connected to GE 2 port)
3. I enabled GVRP on the TRUNK ports only for all switches.
4. I allowed all vlans on the TRUNK ports. (#switchport trunk allowed vlan add all)
5. All TRUNK ports registration mode is NORMAL and dynamic vlan creation is enabled on all trunk and access ports.
6. I created 3 VLANs without configuring its IP Addresses:
     vlan 2 = MGT
     vlan 3 = IT
     vlan 4 = MKTG
I don't know if I missed something on the configuration or the connection. I was expecting the vlans I created will be learned from other switches. Hope somebody can help me out. Thanks a lot.
QUESTIONS:
1. Is it necessary to enable all switches to layer 3 mode? Or depends on the network setup? Does this affect the GVRP?
2. Does switching ports to TRUNK mode means they are already 802.1q ports by default? Because I can't configure TRUNK ports to 802.1q (#switchport encapsulation dot1q) config like other switches.
SAMPLE CONFIGURATION:
*** START CONFIG***
vlan database
vlan 2-4
exit
interface range gi12,gi24
gvrp enable
exit
gvrp enable
interface vlan 1
ip address 172.10.10.10 255.255.255.0
exit
interface vlan 1
no ip address dhcp
exit
no bonjour enable
bonjour interface range vlan 1
hostname SW1
line telnet
exec-timeout 0
exit
line telnet
password 1e3855b6b22c5775cd12207ced02a082b073e4a8 encrypted
exit
line console
exit
enable password level 15 encrypted 1e3855b6b22c5775cd12207ced02a082b073e4a8
no snmp-server server
clock source sntp
no ip domain lookup
ip telnet server
banner login ^C
SWITCH 1: PLEASE DO NOT LOG IN
^C
interface gigabitethernet1
switchport mode access
exit
interface gigabitethernet2
exit
interface gigabitethernet11
exit
interface gigabitethernet12
switchport trunk allowed vlan add 2-4
exit
interface gigabitethernet13
exit
interface gigabitethernet14
exit
interface vlan 2
name MGT
exit
interface vlan 3
name IT
exit
interface vlan 4
name MKTG
exit
*** END CONFIG ***
I created the VLANs manually on each swtich and everything is working fine now. But I configured the IP addresses of each of the VLANs on my core switch only. I can ping now the VLAN's ip from client switches and from any computer that is a member of a VLAN. I'm still don't know how GVRP function as defined.
trust me i am also heaving
trust me i am also heaving the same issue with my 3 Cisco SF300-24 ports ad i need the same what you was looking forward for...
can you please check my question and comment what i am missing :(
Aside to this i will try creating Vlans on my client switch without assigning the ip address as it's already assign and created on core switch.
Sandy
Hi! I have the same issue
Hi!
I have the same issue configuring and creating dynamic vlan thought GVRP...
I enabled it on both switches but VLAN wer not dynamically created on connected switch
2674
