Hardware failure on Nexus 3548 switch
Suddenly my Nexus switch was unreachable and when i logged in through console i found all the ports are in faulty state with the below error message. Any known solution for this case.
Device Model:3548P-10G
Version : version 6.0(2)A1(1b)
2014 Nov 16 23:12:23 SW1 %NOHMS-2-NOHMS_DIAG_ERROR: Module 1: Runtime diag detected major event: Port failure: Ethernet1/43
2014 Nov 16 23:12:23 SW1 %NOHMS-2-NOHMS_DIAG_ERROR: Module 1: Runtime diag detected major event: Port failure: Ethernet1/44
2014 Nov 16 23:12:23 SW1 %NOHMS-2-NOHMS_DIAG_ERROR: Module 1: Runtime diag detected major event: Port failure: Ethernet1/29
2014 Nov 16 23:12:23 SW1 %NOHMS-2-NOHMS_DIAG_ERROR: Module 1: Runtime diag detected major event: Port failure: Ethernet1/30
2014 Nov 16 23:12:23 SW1 %NOHMS-2-NOHMS_DIAG_ERROR: Module 1: Runtime diag detected major event: Port failure: Ethernet1/31
2014 Nov 16 23:12:24 SW1 %NOHMS-2-NOHMS_DIAG_ERROR: Module 1: Runtime diag detected major event: Port failure: Ethernet1/32
2014 Nov 16 23:12:24 SW1 %NOHMS-2-NOHMS_DIAG_ERROR: Module 1: Runtime diag detected major event: Port failure: Ethernet1/13
2014 Nov 16 23:12:24 SW1 %NOHMS-2-NOHMS_DIAG_ERROR: Module 1: Runtime diag detected major event: Port failure: Ethernet1/14
2014 Nov 16 23:12:24 SW1 %NOHMS-2-NOHMS_DIAG_ERROR: Module 1: Runtime diag detected major event: Port failure: Ethernet1/15
2014 Nov 16 23:12:24 SW1 %ETHPORT-5-IF_DOWN_HW_FAILURE: Interface Ethernet1/47 is down (Hardware Failure)
2014 Nov 16 23:12:24 SW1 last message repeated 1 time
2014 Nov 16 23:12:24 SW1 %NOHMS-2-NOHMS_DIAG_ERROR: Module 1: Runtime diag detected major event: Port failure: Ethernet1/16
2014 Nov 16 23:12:24 SW1 %NOHMS-2-NOHMS_DIAG_ERROR: Module 1: Runtime diag detected major event: Port failure: Ethernet1/37
2014 Nov 16 23:12:24 SW1 %NOHMS-2-NOHMS_DIAG_ERROR: Module 1: Runtime diag detected major event: Port failure: Ethernet1/38
2014 Nov 16 23:12:24 SW1 %NOHMS-2-NOHMS_DIAG_ERROR: Module 1: Runtime diag detected major event: Port failure: Ethernet1/39
2014 Nov 16 23:12:24 SW1 %NOHMS-2-NOHMS_DIAG_ERROR: Module 1: Runtime diag detected major event: Port failure: Ethernet1/40
2014 Nov 16 23:12:24 SW1 %NOHMS-2-NOHMS_DIAG_ERROR: Module 1: Runtime diag detected major event: Port failure: Ethernet1/25
2014 Nov 16 23:12:24 SW1 %NOHMS-2-NOHMS_DIAG_ERROR: Module 1: Runtime diag detected major event: Port failure: Ethernet1/26
2014 Nov 16 23:12:24 SW1 %NOHMS-2-NOHMS_DIAG_ERROR: Module 1: Runtime diag detected major event: Port failure: Ethernet1/27
2014 Nov 16 23:12:24 SW1 %NOHMS-2-NOHMS_DIAG_ERROR: Module 1: Runtime diag detected major event: Port failure: Ethernet1/28
2014 Nov 16 23:12:24 SW1 %ETH_PORT_CHANNEL-5-PORT_INDIVIDUAL_DOWN: individual port Ethernet1/47 is down
2014 Nov 16 23:12:25 SW1 %ETHPORT-5-IF_DOWN_HW_FAILURE: Interface Ethernet1/48 is down (Hardware Failure)
2014 Nov 16 23:12:25 SW1 last message repeated 1 time
2014 Nov 16 23:12:25 SW1 %ETH_PORT_CHANNEL-5-PORT_INDIVIDUAL_DOWN: individual port Ethernet1/48 is down
2014 Nov 16 23:12:25 SW1 %ETHPORT-5-IF_DOWN_HW_FAILURE: Interface Ethernet1/17 is down (Hardware Failure)
2014 Nov 16 23:12:25 SW1 %ETHPORT-5-IF_DOWN_HW_FAILURE: Interface Ethernet1/18 is down (Hardware Failure)
2014 Nov 16 23:12:26 SW1 last message repeated 1 time
2014 Nov 16 23:12:26 SW1 %ETHPORT-5-IF_DOWN_HW_FAILURE: Interface Ethernet1/7 is down (Hardware Failure)
Everyone's tags (1)
1 REPLY
Silver
I would highly recommend that
I would highly recommend that you contact Cisco TAC, they will gladly assist you with your trouble, and if its damage, replace it if you a SmartNET contract with Cisco :)
You can e-mail them directly: tac@cisco.com
Just a heads up, provide in your e-mail your Cisco.com user ID, Serial of device and Contract number(s) since they will ask it :D
Rate or mark as correct helpful post! :)
237
