Having minor error for SUP6-E
We are facing issue of having minor error for SUP module details below,
SUP: WS-X45-SUP6-E
Please see the minor error coming  while troubleshooting this SUP 6-E error as below,
module 3: SerialNo :
Overall diagnostic result: MINOR ERROR
Test results: (. = Pass, F = Fail, U = Untested)
1) supervisor-bootup ---------------> U
2) linecard-online-diag ------------> F
Please suggest on this. Also attaching the capture's taken while troubleshooting this SUP.
Ashutosh
  • LAN Switching and Routing
First of all consider this:
00:00:43: %C4K_REDUNDANCY-2-NON_SYMMETRICAL_REDUNDANT_SYSTEM: STANDBY:Main memory mismatch. Active supervisor has 1048576K memory. Standby supervisor has 524288K memory. Redundancy feature may not work as expected.
%C4K_REDUNDANCY-2-NON_SYMMETRICAL_REDUNDANT_SYSTEM: [char]
For the redundancy utility to operate properly, the system must be configured with
symmetrical hardware and software. A mismatch in hardware has been detected between the
active and standby systems. Redundancy operations cannot be guaranteed.
Recommended Action: Configure the hardware so that the active and standby supervisors are
identical in all respects.
upgrading the memory of the Active Sup or downgrading the memory of the backup Sup is
necessary for the SSO mode in order to guarantee the redundancy .
upgrading the memory of the Standby Sup or downgrading the memory of the active Sup is
The other thing is that you cazn be also failing some HW test. I would recomend to sort the memory question first. That will also make you to reseat the standby SUP and make sure that it is seated in chassis  tightly.
Then check for Minor error again. If present - continue with RMA.
Nik
Hall of Fame Super Gold
I'm not sure if this command is valid for the 4500 but can you post the output to the command "sh diagnostic result mod 1 failure"?
Find below the output commands and logs,
Switch#sh diagnostic res
Switch#sh diagnostic result mod
Switch#sh diagnostic result module
module 3: SerialNo : JAE1342LC3R
Overall diagnostic result: PASS
1) supervisor-bootup ---------------> .
2) linecard-online-diag ------------> .
Switch#
*Feb 13 03:12:52.799: %C4K_IOSMODPORTMAN-6-MODULEINSERTED: Module 4 is inserted
*Feb 13 03:13:06.883: %C4K_TRANSCEIVERMAN-3-SEEPROMREADFAILED: Failed to read transceiver serial eeprom on port Te4/2, try reinserting
Switch#
*Feb 13 03:14:22.171: %C4K_REDUNDANCY-6-DUPLEX_MODE: The peer Supervisor has been detected
*Feb 13 03:14:40.511: %C4K_IOSMODPORTMAN-6-MODULEONLINE: Module 4 (WS-X45-SUP6-E S/N: JAE1249277A Hw: 1.2) is online
*Feb 13 03:14:40.511: %C4K_REDUNDANCY-2-NON_SYMMETRICAL_REDUNDANT_SYSTEM: Main memory mismatch. Active supervisor has 1048576K memory. Standby supervisor has 524288K memory. Redundancy feature may not work as expected.
*Feb 13 03:14:40.511: %C4K_REDUNDANCY-6-MODE: ACTIVE supervisor initializing for rpr mode
*Feb 13 03:14:41.171: %C4K_REDUNDANCY-3-COMMUNICATION: Communication with the peer Supervisor has been established
*Feb 13 03:14:41.187: %C4K_REDUNDANCY-5-CONFIGSYNC: The bootvar has been successfully synchronized to the standby supervisor
*Feb 13 03:14:41.187: %C4K_REDUNDANCY-5-CONFIGSYNC: The config-reg has been successfully synchronized to the standby supervisor
*Feb 13 03:14:41.187: %C4K_REDUNDANCY-5-CALENDAR: The calendar has been successfully synchronized to the standby supervisor for the first time
*Feb 13 03:14:41.187: %C4K_REDUNDANCY-5-CONFIGSYNC: The startup-config has been successfully synchronized to the standby supervisor
*Feb 13 03:14:41.415: %C4K_REDUNDANCY-5-CONFIGSYNC: The private-config has been successfully synchronized to the standby supervisor
*Feb 13 03:14:42.475: %C4K_REDUNDANCY-5-CONFIGSYNC_RATELIMIT: The vlan database has been successfully synchronized to the standby supervisor
*Feb 13 03:14:42.479: %RF-5-RF_TERMINAL_STATE: Terminal state reached for (RPR)
Switch#
Switch#
Switch#
Switch#
Switch#
Switch#sh diagnostic result module                             en                             sh diagnostic result module
module 4: SerialNo :
Switch#
Switch#
Switch#  sh diagnostic result module
Switch#
Did you try re-seating the line card or moving the line card into a different slot?
Do upgrade memory on standby to the same ammount as on active first!!! or downgrade memory on active to the same as on standby.
We can clearly see that one SUP (possibly the one coming online later) is showing minor error. Either 3rd is with error or 4th:
module 4:   SerialNo : JAE1249277A
OR:
So the memory test is telling you about the problem to solve at a first:
Please fix memory and check!
Nik
1215
