Community Member
Heat Dissipation by the Cisco Devices
Please help in finding the Heat dissipation or Heat generated by the cisco devices in the attachment.
Any Quick Reply will be appreciated.
M AWAIZ ALI
1 REPLY
VIP Super Bronze
Hi Mohammad,
To figure out the heat dispersion and power consumption for your 6500, use the power calculator using this link:
http://tools.cisco.com/cpc/
It all depend on the numbers and types of modules, Sups, etc... you have in the chassis.
As for the 3750 series, that is in the data sheet:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5023/product_data_sheet0900aecd80371991.html
842
