Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Heat Output from Cisco 3750
Does anyone know what the heat output from a 3750 switch is? I have had a look at the documentation but cannot find the answer. We need to know for air-conditioning purposes. many thanks
Re: Heat Output from Cisco 3750
Check the Technical Specification in the Product Installation Guide for Cisco Catalyst 3750 Switches http://www.cisco.com/en/US/products/hw/switches/ps5023/products_installation_guide_chapter09186a00807c6691.html
Thanks but I checked this and the info isn't there
I'm looking for the same info for the 2960G-48TC. The tech sheet doesn't list it, and I got the run-around from tech support.
1014
