help 1812w router
Kananavicius
HI
I have 1812w access router
So he has 2 wan ports 8 switch ports
When I connect my WAN port 0 to the WAN my router has the internet
It is no problem to connect another port 1 to my LAN and LAN has as well Internet
When I plug another PC to the switch port 2 my PC does not have the Internet connection so how to do that my all 8 switch port will have the de same Internet as has router
and all PC Witch one is connected to switch port will have the Internet
as my LN
Thank you
m-haddad
Level 5
Level 5
You have to use PAT on the router to allow your LAN to access the internet. Check the below link for sample config
http://www.cisco.com/en/US/tech/tk175/tk15/technologies_configuration_example09186a0080093e51.shtml
Please rate if I was helpful,
I have readied that publication before
And using the NAT
I need that 8 switch ports on my router will have the same Internet as
May port fa1 192.168.1.0 inside
So how to do that all 8 switch pots on the same router will se the fa1
Because it do not se and it can?t forward the packets from fa1 to
my 8 switch ports an back on the same router 1812w
I guess i got your scenario.
on the router remove the IP from port 1.
go to the configuration mode and set the ip on the interface VLAN1
and then all PCs who connect to the switch will have internet because all the switch ports are by default in VLAN 1
Please let me know if it works,
