Help Access-list on Router not match correctly
I use to redirect access list for ip 192.168.13.5 with port 80 and 443
but all access list is match to deny
any suggestion ?
-----------------------------------Here is Log and Config on Router--------------------------------------------------------------------
Feb 12 06:45:59.210: %SEC-6-IPACCESSLOGP: list proxy denied tcp 74.125.128.147(443) -> 10.0.10.208(58742), 1 packet
Router2911(config-if)#
Feb 12 06:46:00.410: %SEC-6-IPACCESSLOGP: list proxy denied tcp 124.40.234.198(443) -> 192.168.13.5(54559), 1 packet
Feb 12 06:46:01.434: %SEC-6-IPACCESSLOGP: list proxy denied tcp 124.40.234.198(443) -> 192.168.13.5(54559), 1 packet
Feb 12 06:46:02.614: %SEC-6-IPACCESSLOGP: list proxy denied tcp 17.151.226.77(443) -> 10.0.10.76(59237), 1 packet
Feb 12 06:46:03.638: %SEC-6-IPACCESSLOGP: list proxy denied tcp 27.254.34.69(80) -> 10.0.10.110(1545), 1 packet
Router2911(config-if)#do show access-li proxy
Extended IP access list proxy
    1 deny tcp host 192.168.9.15 any eq www
    2 deny tcp host 192.168.9.15 any eq 443
    3 permit tcp any host 192.168.13.5 eq www
    4 permit tcp any host 192.168.13.5 eq 443
    5 permit tcp host 192.168.13.5 any eq www
    6 permit tcp host 192.168.13.5 any eq 443
    30 deny ip any any log (19392481 matches)
Router2911(config-if)#do show access-li Inside_nat_outside
Extended IP access list Inside_nat_outside
    5 deny tcp host 192.168.13.5 any eq www (1003 matches)
    6 deny tcp host 192.168.13.5 any eq 443 (2241 matches)
    450 permit ip any any (1055799 matches)
ip nat inside source list Inside_nat_outside interface GigabitEthernet0/0 overload
Router2911(config-if)#do show run int gi0/0
Building configuration...
Current configuration : 213 bytes
ip address "Connect to internet"
ip wccp 1 redirect out
ip wccp 62 redirect in
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
crypto map CRYPTO
end
Router2911(config-if)#do show run int gi0/1
Current configuration : 189 bytes
interface GigabitEthernet0/1
ip address "Connect to Client"
ip wccp 61 redirect in
ip nat inside
duplex auto
speed auto
end
Router2911(config-if)#do show run int gi0/2
Current configuration : 165 bytes
interface GigabitEthernet0/2
ip address "Connect to Proxy"
ip wccp 1 redirect in
ip nat inside
duplex auto
speed auto
end
---------------------------------------------End of Router Log and Config----------------------------------------------
183
