Help in implementing PBR/Route-maps default route to 2nd ISP remote site
I am trying to create a route-map to have a specific VLAN in our 6509-Rter to default route and use
outbound internet through MCI ISP. Internal routing is OSPF, the 6509Rter gateway of last resort is
out through ISPQwest, we have a 100 MB wan link between the 6509-Rter, on the 6506Rter I made its default
route to go out the ISPMCI. On the PIX I have created the nessesary access-list and PAT for outbound connections.
The reason I would want to route the especific VLAN on the 6509Rter is because our T1 to the internet from the
Qwest side has been bursting so internet is very slow, on the MCI side we have unlimited internet bandwidth
and until we upgrade the internet T1 I need to accomodate critical outbound traffic for some systems retreaving
time sensitive market data information from the internet.
Could someone give me some examples .
This is the tolopogy :
Internal Routing is OSPF and default route is out through Qwest.
On the 6506Rter its default route is statically given to go out the MCI ISP
Phisical
ISPQWEST<-->PIX515E<-FE->6509Rter<--100MB-WAN->6506router<-FE->2811Rter<-FE->PIX515e-->ISPMCI
Logical
6509Rter-10.10.0.2><10.10.0.1-6506Rter-192.168.12.1><192.168.12.2-2811Rter><192.168.2.1><To-PIX515e
On the 6509Rter I have created the route map for a test subnet but it did not work, what did I missed?
6509Rter
interface vlan22
ip address 10.168.100.2
ip policy route-map cadlab-traffic
access-list 100 permit ip host 10.168.100.2
route-map cadlab-traffic permit 10
match ip address 1
set ip default next-hop 10.10.0.1
Jorge
Bronze
Re: Help in implementing PBR/Route-maps default route to 2nd ISP
As far as I can see you should have :
match ip add 100, not 1 ?
Bjornarsb
Bronze
Have a look on this basci exa.
Bjornarsb
Hey bjornarsb, thanks for your imput.. I did corrected your observations but still I was having issues yesterday not being able to re-route www traffic out to the other ISP, until this morning when I try adding a host on the the access list. I ended up creating a whole new script and it worked.
I have placed the basic topology diagram so that I can share with others the solution.
The new script I created was the following:
On the BOSTON Core-6509:
interface Vlan23
description TEST_Segment_10.169.100.0/2
ip address 10.169.100.2 255.255.255.0
no ip redirects
no ip proxy-arp
standby 23 ip 10.169.100.1
standby 23 priority 20
standby 23 preempt
standby 23 authentication msfc_v23
standby 23 name TEST_Segment
access-list 1 permit 10.169.100.1
access-list 1 permit 10.169.100.2
access-list 1 permit 10.169.100.10 ( Added )
match ip address 1
set ip next-hop 10.10.0.1
So basically I added the 10.169.100.10 PCs-IP in acl 1 and all wwww traffic redirected to COLO-site ISP-2
Jorge
Bronze
Hi again,
That was good news!
Please rate if the exa. I posted helped you
identifing you problem.
Bjornarsb
126
