Help in Routing to Default Route
khuramraza1986
Greetings,
i have a Cisco 2911 router, am connecting 2 subnets 192.168.1.0/24 and 192.168.2.0/24 to Internet
somehow its not working, only router is able to ping any external IP but client's can't, client's can commnicate with each other (on different subnet smoothly), below is a short summary of my config
GE 0/0 - Connected to Modem, Interface IP 192.168.4.3, Modem IP 192.168.4.1
GE 0/1 - Connected to Switch with all 192.168.3.0/24 subnet
GE 0/2 - Connected to Switch with all 192.168.1.0/24 subnet
Router rip - active  - networks 192.168.3.0 and 192.168.1.0 added to it
default route is active to 192.168.4.1 with following command
ip route 0.0.0.0 0.0.0.0 192.168.4.1
in above case, router can ping to any internet IP. but client's cant.
can any one help ?
Your adsl modem/router will need to know how to get back to two subnets, so you'll need to add two static routes for 192.168.1.0/24 and 192.168.3.0/24. The adsl router only knows about 192.168.4.0/24 which is why the router is the only thing that can get out. The problem that you may have is that the adsl router won't support more than one subnet (especially if it's a home/soho router). If that's the case, you may need to check with the isp, you could get a normal adsl modem and then use this router as your primary router. Your public IP would be passed directly to the Cisco and then you could do natting on here.
Another option, if the above doesn't work, is to configure nat on here, but then it would be double natting. You could do something like the following to get this configuration to work:
int g0/0
ip nat out
int g0/1
ip nat ins
int g0/2
ip nat ins
access-list 10 permit 192.168.1.0 0.0.0.255
access-list 10 permit 192.168.3.0 0.0.0.255
ip nat inside source list 10 interfac g0/0 overload
Again, this should work but not desired because you're double natting (natting at your router, and then the isp is natting again).
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
10 Replies 10
Reza Sharifi
Do the client subnets have the correct default gateway?
What do the clients connect to?
yes they are correct. for example
a client connected to 3.0 subnet has IP 192.168.3.10 - 255.255.255.0 with Gateway 192.168.3.3 (GE 0/1 Interface IP)
this client can communicate with everyone on 1.0 subnet but cant go outside. below is my sh ip route result
my router can ping anyone outside such as 8.8.8.8, google.com or yahoo.com
Gateway of last resort is 192.168.4.1 to network 0.0.0.0
S*    0.0.0.0/0 [1/0] via 192.168.4.1
     192.168.1.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.1.0/24 is directly connected, GigabitEthernet0/2
L        192.168.1.5/32 is directly connected, GigabitEthernet0/2
R     192.168.2.0/24 [120/1] via 192.168.1.3, 00:00:06, GigabitEthernet0/2
     192.168.3.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.3.0/24 is directly connected, GigabitEthernet0/1
L        192.168.3.3/32 is directly connected, GigabitEthernet0/1
     192.168.4.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.4.0/24 is directly connected, GigabitEthernet0/0
L        192.168.4.3/32 is directly connected, GigabitEthernet0/0
khuramraza1986
Update,
my clients also can't ping GE 0/0 (192.168.4.3 IP) while they can ping GE 0/1 and GE 0/2 's IP addresses
i have even tried to enter 192.168.4.0 in RIP network, no luck
Do you have nat configured on the router, or is something else natting for you?
HTH,
John
hi john,
am not sure about natting, but i think my modem is doing this job
http://support.linksys.com/en-us/support/gateways/WAG320N
above modem is one am using with an IP of 192.168.4.1 and my GE 0/0 is connecting to it via 192.168.4.3 IP
do i need to setup NAT ? inside or outside ? please advise
Have a look at your modem and see what subnet is being NATed.  It maybe NATing only one subnet and if that is the case add the other 2 subnets and try again.
Also, can you post sh run from the router?
thanks for the update, but previously I was only running that modem with switch for around 220 clients in my network. its just a standard adsl router. nothing fancy, no static IP just simple connection.
router was required to add new subnet.
below is my sh run, am not quite sure if i need NAT here. as router should just forward any unknown traffic to modem IP 192.168.4.1.
Building configuration...
Current configuration : 3326 bytes
! Last configuration change at 08:32:57 PCTime Mon Sep 16 2013
version 15.2
hostname RoutingGW
boot-start-marker
boot-end-marker
logging buffered 52000
no aaa new-model
clock timezone PCTime 3 0
ip cef
ip domain name edesign.com.sa
ip name-server 192.168.1.248
ip name-server 192.168.1.250
no ipv6 cef
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description Subnet 10.0 - External$ETH-WAN$
ip address 192.168.4.3 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
description Subnet-3.0$ETH-LAN$
ip address 192.168.3.3 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/2
description Subnet 1.0$ETH-LAN$
ip address 192.168.1.5 255.255.255.0
duplex auto
speed auto
router rip
network 192.168.1.0
network 192.168.3.0
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
privilege level 15
login local
transport input telnet ssh
transport output telnet ssh
scheduler allocate 20000 1000
end
int g0/0
ip nat out
int g0/1
ip nat ins
int g0/2
ip nat ins
HTH,
John
There has been a recent discussion very similar to this in the forum where the original poster was having problems in accessing the internet from subnets connected to the router. He found that doing address translation on the router for the connected inside interfaces did solve his problem. But he was frustrated at needing to do double NAT. My comment to him was that the ISP knew about the one subnet that was connected to the ISP and was doing translation for that subnet. I believe that if he were to request that the ISP do translation for additional subnets that the ISP would be able to do that but that it probably would require a service at a higher level than what was currently in his contract and would probably result in a higher bill. If you do not want to do double NAT then talk to your ISP and request additional translations but be prepared to pay more for the service. If you want to maintain your current billing level then do the double translation on your router.
Rick
Rick
thanks john,
that actually helps, i have to setup NAT.
am a bit confused now, as i have 2 nattings in my network. trying to find a solution for that
