Help in stacking 3 2960 S switche cables
                   Hi all,
I need to stack 3 2960 S series switches together.
Each switch has 2 stack ports 1 and 2.
Need help in how to make right cable connections between them?
MAhesh
Everyone's tags (7)
3 ACCEPTED SOLUTIONS
Hall of Fame Super Bronze
Down means that a cable is detected, but either no connected neighbor is up, or the stack port is disabled. The 2nd option is likely to be the reason here  - check if one of the corresponding ports was disabled on a switch.
You could try
     switch 2 stack port 2 enable
     switch 3 stack port 1 enable
Kind Regards,
Ivan
**Please grade this post if you find it useful.
Kind Regards, Ivan Shirshin **Please grade this post if you find it useful.
Hall of Fame Super Gold
You've got a stacking cable missing or not "clicked" in properly.
Hi Edsion,
Thanks for reply.
Stack#sh switch stack-ports
  Switch #    Port 1       Port 2
    1           Ok           Ok
    2           Ok          Down
    3          Down          Ok
Stack#sh swi
Stack#sh switch
Switch/Stack Mac Address : 58bf.eae5.c300
                                           H/W   Current
Switch#  Role   Mac Address     Priority Version  State
*1       Master 58bf.eae5.c300     5      1       Ready
2       Member 58bf.ea8f.7680     1      1       Ready
3       Member 58bf.ea3f.e380     1      1       Ready
Switches are in stack but few ports are down how can i make all stack ports up up?
MAhesh
You could try
Kind Regards,
Ivan
Hi all,
Thanks eveyone for their help.
I changed the cable connections to switches  and did reboot after that all  switch ports were ok
MAhesh
Thanks Mahesh.
3361
