Community Member
HELP - Licence Error on 4500x VSS
HI there,
have 2 4500x in vss mode. both are running 3.4.2 ipbase and are running on the correct licences etc.
after putting them in VSS mode the following error shows in the logs.
%SW_LEVEL-6-RESULT: Operational redundancy mode is UNKNOWN, due to software license-level mismatch at ACTIVE and STANDBY. Software Level on Active: ipbase; on Standby: ipbase
Any suggestions would be appreciated.
I thought it maybe related to bug CSCui54147 but cant see any details of it and it only seems to relate to 3.5.x
Thanks in advance.
Ross
Everyone's tags (3)
VIP Super Bronze
Hi Ross,Can you post the
Hi Ross,
Can you post the output of "sh switch redu"?
Community Member
Hi Apologies for not getting
Hi Apologies for not getting back.
To fix this I had to manually accept the EULA for ipbase licence on the 4500x.
After the reload everything worked correctly and I stopped getting this error.
46
