Help me for 4510R-E Switch Redundancy
Dear Sir,
Deatails are as follows.
L2 Redundancy:
• Between two Backbone switch there are 3 nos of Links: One is Wireless Link using Canopy and Two 10 Gig are Fiber link which is maintained by STP. ( Primary Link will be 10Gig port because of low cost : 2 than Gig port cost : 4 )
• Between Backbone and Distribution Switch one link will be active and other link will be blocked by STP according to the path cost.
• Primary Root will be ESH (AS ESH side Backbone VLAN STP Priority : 16384 and at Prabhat side Backbone Vlan STP Priority will be 28672 )
L3 Redundancy:
• On both the Backbone Switch HSRP will be used on Backbone Vlan. (ESH side HSRP Priority will be 120 and at Prabhat side HSRP Priority will be 110.)
• Redundancy between TWO SUP on one chassis will be handled by SSO and Config-sync feature with SRM. (Only one SUP will be active at a time.)
I want to use two Ten Gidg Port using Fiber and one Gig port using Canopy Wireless between tweo CORE switches.
On Distribution there will not be HSRP . It is ok or not ?
Pls Reply ....
Pls Give the configuration or what shuod I add in the config I have attached.
Can you pls send me the configuration is possible?
Dipesh P.
1 REPLY
Hall of Fame Super Silver
Re: Help me for 4510R-E Switch Redundancy
Hello Dipesh,
you have already a thread about this.
I've answered there.
Your design can be improved in several ways:
interconnection: adding link between distrib1 and core2
routing: moving to a dynamic routing protocol can change dramatically network capability to react to topology changes see the explanation in other thread.
Hope to help
Giuseppe
165
