06-19-2013 04:51 AM - edited 03-07-2019 01:58 PM
Hi all
I have posted another similar question but I have found something, that Im hoping someone may help
When transferrign files from a windows pc to a windows pc from my office to a remote site the transfers are fine, however when I transfer files from a hpux server 172.31.69.2 to the client the speed is very very slow over the same wan link. However on the local network lan that the server is on its fine.
I have a capture of the transfer, and can see that the DF bit is set to 1 from the server, and its saying bad crc errors "oversize frame" and its retransmitting all the time.
Can anyone help by looking at the capture
06-19-2013 04:59 AM
Hi Carl,
Could you please check what is the speed and duplex configured on the server 172.31.69.2? If this is set to auto change that to 100/Full or 1000/full and configure the same speed setting on the switch port manually rather than switch auto negotiating them.
Hope that should help.
Najaf
Please rate when applicable or helpful !!!
06-19-2013 05:26 AM
Make sure jumbo packets aren't enabled on the servers NIC if your network is not configured for it.
Sent from Cisco Technical Support Android App
06-19-2013 05:37 AM
We have checked the hpux server and the mtu is set to 1500,
both the server and switch are set to auto auto for speed and duplex and are running 1000 full
any other ideas ?
06-19-2013 05:41 AM
Hi Carl,
Try manually configuring them to 1000 full on both server end and switch end. That should fix it
Najaf
06-19-2013 06:53 AM
hi
but nothing has changed on the network or server, and its been happening for only a few weeks now! no errors on the ports etc.
Is the capture anything to go by ?
06-19-2013 07:05 AM
So the transfer from the server was working fine over the WAN and it recently stopped working just to confirm?
06-19-2013 07:27 AM
Yes this is correct, when I say WAN, its a 100meg ethernet connection
No other performance issues on this link.
cheers
06-19-2013 07:46 AM
Hi Carl,
I understand that nothing has changed... But still i feel it would worth a try to reconfigure the both speed and duplex manually on both server and switch end. Believe me this will improve the performance.
Najaf
06-19-2013 12:36 PM
Hi there
The issue is only when we are on other sites, if we connect from the HQ from another vlan to the server its fine, however any of the sites which connect via 100Meb ethernet all seem to have the same issue.
what could this be ? as there is no issue on the other sites and the links are fine!
can anyone find anything in the capture ?
06-19-2013 09:05 PM
From your original post you see df bit set, can you disable this and see if something in the parh is fragmenting the packet. Fragmentation can only happen on an l3 interface and is done in sw. You find the device pinting then you can verify mtu in the path of the paket. Check for features such as mss-adjust which will limit your packet size. Also do u have a tunnel in this path? You have to account for encap overhead.
Hth,
Dale
06-20-2013 08:32 AM
Are all the ports pretty much hard coded that are in this path or setup auto/auto? Can you confirm if all ports are showing up as Full Duplex and none are showing half duplex including your WAN connection from both ends. Check the link utilization also when you try the transfer. Are you using sftp to do the transfer?
