01-11-2008 02:22 AM - edited 03-05-2019 08:24 PM
can someone help me, the router is allways using the second b-channel, please see attached config . the router should only use one B-Channel everytime
01-17-2008 07:27 AM
Actually your router is not correctly configured for multilink PPP. After the first B-channel connects, the CALLING router again dials the same number. The switch at the remote end, closest to the CALLED router recognizes that the first B-channel is busy, and transfers the call onto the second B-channel, and thereby makes bundling possible.
The following link will help you:
http://www.cisco.com/en/US/tech/tk801/tk379/technologies_tech_note09186a0080094b7a.shtml
01-17-2008 10:18 AM
thx for your answer, can you please explain in detail what i have to change than in my config??? or is it better to config a dialer interface where i point all routes to, then. like
interface Dialer99
description Verbindung zu tttttttt
ip address 192.168.5.1 255.255.255.0
no ip directed-broadcast
encapsulation ppp
dialer remote-name zzzzzzzzzz
dialer string xxxxxxxxxxxxxxxxxx
dialer hold-queue 20
dialer load-threshold 200 either
dialer pool 9
dialer-group 9
ppp authentication chap
ppp chap hostname yyyyyyyyyyy
ppp multilink
ip nat inside source static tcp 10.0.255.10 6010 interface dialer99 6010
ip nat inside source static tcp 10.0.255.10 6000 interface Dieler99 6000
and so on, or can i leave the IP nat as it is
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.5.2
ip route 192.168.0.0 255.255.255.0 192.168.5.2
ip route 192.168.1.1 255.255.255.255 Dialer99
ip route 192.168.3.0 255.255.255.0 192.168.5.2
ip route 192.168.5.2 255.255.255.255 Dialer99
Best regards Ralf
