Webcast-Catalyst9k
Help on enabling GB ports on 8540 CSM
I have just been given a used 8540 for our organization. We are trying to bring up the gi ports but when I connect a patch cable to another switch the port says it is "administratively down, protocol down" how do I get the ports to come up?
1 REPLY
Silver
Re: Help on enabling GB ports on 8540 CSM
Issue the following commands
Router#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#int Gi2/0/2
Router(config-if)#no shutdown
Router(config-if)#exit
Router(config)#exit
Router#
Replace Gi2/0/2 with your Gigabit interface.
121
