Help to configure cisco
Hello everyone,
I need your help here I try to configure a Cisco 881 router when infact I have a connection that reaches the Wan port on the router I configure 88.XXX (public ip) I put the default gateway etc.. his short works because when I ping the IP on the outside it works
my problem i want to  have internet on my port FastEthernet 0 , I configured a dhcp pool top 192.168.0.X it works but I do not have internet despite having set nat inside outside putting the road so I added a static route but it's not work copy of my config thank you.
1#show running-config
Building configuration...
Current configuration : 5424 bytes
! Last configuration change at 15:56:09 UTC Thu Mar 13 2014 by admin
version 15.2
no service pad
hostname R1
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
memory-size iomem 10
crypto pki trustpoint TP-self-signed-2132292671
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2132292671
revocation-check none
rsakeypair TP-self-signed-2132292671
crypto pki certificate chain TP-self-signed-2132292671
certificate self-signed 01
3082022B XXXXXXXXXXXXXXXXXXXXXXXXXXXX
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 192.168.0.254
ip dhcp pool ccp-pool
import all
network 10.10.10.0 255.255.255.248
default-router 10.10.10.1
lease 0 2
ip dhcp pool vlan5
network 192.168.0.0 255.255.255.0
default-router 192.168.0.254
dns-server 8.8.8.8
no ip domain lookup
ip domain name yourdomain.com
ip cef
no ipv6 cef
license udi pid CISCO881-K9 sn FCZ18047124
ip ssh version 2
interface FastEthernet0
switchport access vlan 5
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
ip address 84.14.XXX.X 255.255.255.248
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Vlan1
description $ETH_LAN$
ip address 10.10.10.1 255.255.255.248
ip tcp adjust-mss 1452
interface Vlan5
ip address 192.168.0.254 255.255.255.0
ip default-gateway 84.14.209.185
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 2 interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 84.14.209.185
access-list 2 permit 192.168.0.0 0.0.0.255
no cdp run
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username <myuser> privilege 15 secret 0 <mypassword>
Replace <myuser> and <mypassword> with the username and password you
want to use.
^C
banner login ^C
Cisco Configuration Professional (Cisco CP) is installed on this device.
This feature requires the one-time use of the username "cisco" with the
password "cisco". These default credentials have a privilege level of 15.
YOU MUST USE CISCO CP or the CISCO IOS CLI TO CHANGE THESE
PUBLICLY-KNOWN CREDENTIALS
Here are the Cisco IOS commands.
no username cisco
Replace <myuser> and <mypassword> with the username and password you want
to use.
IF YOU DO NOT CHANGE THE PUBLICLY-KNOWN CREDENTIALS, YOU WILL
NOT BE ABLE TO LOG INTO THE DEVICE AGAIN AFTER YOU HAVE LOGGED OFF.
For more information about Cisco CP please follow the instructions in the
QUICK START GUIDE for your router or go to http://www.cisco.com/go/ciscocp
^C
line con 0
login local
no modem enable
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
password
login
transport input ssh
line vty 5 15
access-class 23 in
privilege level 15
login local
transport input telnet ssh
end
1 ACCEPTED SOLUTION
Add the below interface
Add the below
interface Vlan5
ip nat inside
Add the below
interface Vlan5
ip nat inside
This is all it was missing ?
It works thank's !!
94
