10-21-2008 10:44 AM - edited 03-06-2019 02:03 AM
Hi proz,
I need help configuring my 3825 router and 3560 switch for voip setup.
1)Basic configuration(as these are out of box).Any config docs or step by step guidance would be great.
2)Enable dhcp on both the devices.
3)Auto qos need to be enabled for all the vlans.
Ip address DATA - 105.152.40.0/23
VOICE - 105.152.240.0/24
needs to be assigned.
your help or post would be of great help.
Thanks in advance.
Solved! Go to Solution.
10-23-2008 01:16 PM
Hi there,
Try applying this configuration to your 3825 router:
ip dhcp pool DATA
network 105.152.40.0 255.255.252.0
domain-name
dns-server
netbios-name-server
default-router 105.152.41.254
ip dhcp pool VOICE
network 105.152.240.0 255.255.255.0
domain-name
dns-server
netbios-name-server
default-router 105.152.240.254
If you have a CallManager server for your IP phones to register to, or a CallManager Express instance, or any other IP-PBX compatible with Cisco IP Phones, then you'll want to set DHCP option 150 on your VOICE scope, like this:
ip dhcp pool VOICE
option 150 ip
Hope this helps!
Kind regards
Graeme
10-22-2008 12:06 AM
Hi there,
Are you going to be using a Cisco CallManager) server, or will you be using CallManager Express (CCME), or are you going to be connecting your 3825 to a PBX and using the router as an analog voice gateway?
Anyway, here's a basic router config (no DHCP, no voice interfaces (not sure what you have)):
version 12.4
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
hostname
boot-start-marker
boot-end-marker
logging buffered 8192 informational
enable secret
no aaa new-model
ip cef
no ip domain lookup
archive
log config
hidekeys
class-map match-any BULK
description Bandwidth Intensive Interactive Data Applications
match ip dscp af32
match ip dscp af33
class-map match-any SIGNALLING
description VOIP Signalling
match ip dscp cs3
class-map match-any REAL-TIME
description REAL-TIME Traffic
match ip dscp ef
class-map match-any INTERACTIVE
description Interactive Data Applications
match ip dscp af21
match ip dscp af22
match ip dscp af23
class-map match-any VIDEO
description Video Conference
match ip dscp af41
match ip dscp af42
match ip dscp af43
policy-map QOS-OUT
class REAL-TIME
priority percent 30
class VIDEO
bandwidth percent 15
class BULK
class INTERACTIVE
bandwidth percent 10
class SIGNALLING
bandwidth percent 5
class class-default
fair-queue
random-detect
interface GigabitEthernet0/0
description Connection to your switch port FastEthernet0/1
no ip address
ip route-cache flow
load-interval 30
duplex full
speed 100
media-type rj45
service-policy output QOS-OUT
interface GigabitEthernet0/0.10
description DATA
encapsulation dot1Q 10 native
ip address 105.152.41.254 255.255.254.0
interface GigabitEthernet0/0.20
description VOICE
encapsulation dot1Q 20
ip address 105.152.240.254 255.255.255.0
h323-gateway voip interface
h323-gateway voip bind srcaddr 105.152.240.254
interface GigabitEthernet0/1
no ip address
shutdown
no ip http server
no ip http secure-server
line con 0
password
stopbits 1
line aux 0
password
transport input telnet
stopbits 1
line vty 0 4
password
line vty 5 15
password
end
With the DHCP configuration, that should be enough to get your phones on one VLAN and your PCs on another, plus set the router up as an H323 gateway. I haven't included any voice hardware configuration (voice port) or dial-peers to the router as I don't know what WICs you're going to use (FXO, FXS, T1/E1, E&M, etc) or if you're using CallManager, CallManager Express, or just gateway-to-gateway.
Hope this is of some help anyway
Kind regards,
Graeme
10-22-2008 12:07 AM
And here's the config for the switch:
version 12.2
no service pad
hostname
enable secret
no aaa new-model
system mtu routing 1500
vtp domain NON-VTP
vtp mode transparent
udld enable
ip subnet-zero
no ip source-route
no ip domain-lookup
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
vlan 10
name DATA
vlan 20
name VOICE
interface FastEthernet0/1
description Connection to your 3825 port G0/0
switchport trunk native vlan 10
switchport trunk allowed vlan 1,10,20
switchport mode trunk
priority-queue out
auto qos voip trust
mls qos trust dscp
interface range FastEthernet0/2 - 24
switchport access vlan 10
switchport mode access
switchport voice vlan 20
no logging event link-status
no snmp trap link-status
priority-queue out
auto qos voip cisco-phone
spanning-tree portfast
interface GigabitEthernet0/2
mls qos map cos-dscp 0 8 16 24 32 46 48 56
interface Vlan1
no ip address
interface Vlan10
description DATA
ip address 105.152.41.240 255.255.254.0
ip default-gateway 105.152.41.254
ip classless
no ip http server
control-plane
line con 0
exec-timeout 15 0
password
line vty 0 4
exec-timeout 15 0
password
length 0
line vty 5 15
exec-timeout 15 0
password
length 0
end
10-22-2008 04:38 AM
Need trunking established from router to switch and qos enabled on switch for voice and all ports configured on swith for phones.
I have only to setup router and switch setup,i dont have to worry about T1 and dial peers(voice components).
I need to create a management IP on the switch to enable telnet to it for management.
Default route on router will be 105.152.41.254 ( which is the ip address of wan router).
Enable dhcp on both networks such that i can test my configuration with a pc and ip phone.
And finally,i need to setup router in such a way that it is password protected from telnet and console.
10-22-2008 12:17 PM
Hi there,
I set up trunking - your Gigabit 0/0 interface on the 3825 config is divided into Subinterfaces G0/0.10 and 0/0.20. Note the "encapsulation dot1q" command on the router.
If you also look at F0/1 on the 3560 config, that has been configured to do 802.1Q trunking between the switch and the router. Configure your switch and router and connect G0/0 on the router to F0/1 on the switch and they will establish a 802.1Q trunk with VLAN 10 being native.
The VLAN 10 interface on the switch has been configured with a management IP address (there's no problem having a management IP address from the data VLAN; all our switches have this).
You would probably be better off with an actual server running your DHCP service, and using DHCP relay from the subinterfaces of the router, but I can get you a DHCP scope config tomorrow if you like.
AutoQoS is enabled on all the switchports and I've given you some QoS config for the router (need more info to be able to do any better, unfortunately).
On the lines that say "
10-23-2008 04:36 AM
Hi Graeme,
If you could then please provide me with DHCP scope config within ip addr range which i mentioned earlier and it has to be for both the voice and data.
THANK YOU
10-23-2008 01:16 PM
Hi there,
ip dhcp pool DATA
domain-name
dns-server
netbios-name-server
ip dhcp pool VOICE
domain-name
dns-server
netbios-name-server
ip dhcp pool VOICE
option 150 ip
Hope this helps!
Kind regards
Graeme
