Help with Multicast - multicast traffic not crossing WAN
I've deployed multicast configuration but I'm can't see multicast traffic coming down the wan.
Here's what I've done:
vlan 50 is where the servers are sitting at site1 and they need to receive mutlicast traffic from site 2 vlan 8.
Site 1:
Switch1
interface Vlan50
ip address 10.44.50.253 255.255.255.0
no ip redirects
no ip unreachables
ip pim sparse-mode
standby 50 ip 10.44.50.1
standby 50 timers 1 2
standby 50 priority 120
standby 50 preempt
WAN link at site 1 switch1:
interface GigabitEthernet1/0/50
no switchport
ip address 10.10.51.105 255.255.255.252
ip pim query-interval 1
ip pim sparse-mode
load-interval 30
Site 1 Switch 2:
interface Vlan50
ip address 10.44.50.254 255.255.255.0
standby 50 priority 105
standby 50 preempt
WAN link at site 1 switch2:
interface GigabitEthernet1/0/51
no switchport
ip address 10.10.51.145 255.255.255.252
load-interval 30
Site2 Switch1:
interface Vlan8
ip address 10.45.8.254 255.255.255.0
ip pim sparse-mode
standby 8 ip 10.45.8.1
standby 8 priority 110
standby 8 preempt delay minimum 60
hold-queue 2048 in
WAN link at site 2 switch1:
interface GigabitEthernet1/43
ip address 10.10.51.106 255.255.255.252
ip flow ingress
ip pim sparse-mode
ip route-cache flow
Site2 Switch2:
interface Vlan8
ip address 10.45.8.253 255.255.255.0
ip pim sparse-mode
hold-queue 2048 in
WAN link at site 2 switch2:
ip address 10.10.51.146 255.255.255.252
ip flow ingress
ip pim sparse-mode
ip route-cache flow
Can someone see a reason why Site 1 vlan 8 isn't getting multicast traffic for multicast group 239.255.3.20.
Just so you are aware we have an appplication that is sending the multicast via tcp across the wan link then multicasting it into site 1. I want to remove this application and instead have multicast traffic traverse the wan link in raw form.
Any thoughts?
Thanks in advance
Dan
Re: Help with Multicast - multicast traffic not crossing WAN
Hello Dan,
I assume you have the "ip multicast-routing" or "ip multicast-routing distributed" configured on your switches as your configuration requires Layer3 multicast routing.
What does the "show ip mroute" say about the group 239.255.3.20? Is the outgoing interface list Null or does it contain correct interfaces? Also, you are using PIM-SM - is there a RP (rendezvous point) router known to all your multicast-routing switches?
Best regards,
Peter
Thanks for your reply.
Yes I have in all sites ip multicast-routing configured. Here's the MSDP config's in each site:
Site1 Switch1:
ip pim rp-address 10.44.100.100
ip msdp peer 10.44.100.252 connect-source Loopback1
ip msdp keepalive 10.44.100.252 10 30
ip msdp cache-sa-state
ip msdp timer 1
Site1 Switch2:
ip msdp peer 10.44.100.253 connect-source Loopback1
ip msdp keepalive 10.44.100.253 10 30
ip msdp timer 1
Site2 Switch1:
mls ip multicast flow-stat-timer 9
mls aging long 64
mls aging normal 64
mls flow ip interface-full
no mls flow ipv6
mls nde sender version 5
no mls acl tcam share-global
mls cef error action reset
ip pim rp-address 10.239.45.1
ip msdp peer 10.45.255.253 connect-source Loopback1
ip msdp originator-id Loopback1
Site 2 Switch2:
mls aging long 64
mls aging normal 64
no mls flow ipv6
ip pim spt-threshold infinity
ip msdp peer 10.45.255.254 connect-source Loopback1
Any thoughts on this?
Dan
The show ip mroute is quite long, here's an abstract from it:
(*, 239.255.3.20), 16:27:22/stopped, RP 10.44.100.100, flags: SP
Incoming interface: Null, RPF nbr 0.0.0.0
Outgoing interface list: Null
(10.44.50.34, 239.255.3.20), 01:29:51/00:02:58, flags: PT
Incoming interface: Vlan50, RPF nbr 0.0.0.0
Hi Guys,
Any thoughts on this, could this be related to autorp? do I need to enable this on both sides. If I do what problems could come up with this enabled?
Dan
Hi Dan,
You do not need the AutoRP because apparently on all switches you have your RP configured statically. The question is, why does the mroute table contain NULL oif list for the multicast group in question.
Try to proceed from the switch nearest to the servers and check the "show ip igmp group" whether it knows about the multicast group in question. If yes, the group should be indicated with a VLAN SVI interface indicating that the SVI interface is connected to a network with receivers. Now, from this switch backwards to the source, watch for the "show ip mroute" entries regarding this multicast group - they must have their RPF neighbor identified and their oif list must not be NULL.
Best regards,
Peter
Thanks for the advice. Here's my ouptuts
Site 2 Switch1:
show ip igmp group
IGMP Connected Group Membership
Group Address Interface Uptime Expires Last Reporter
239.255.3.20 Vlan8 28w1d 00:02:13 10.45.8.38
show ip mroute:
(*, 239.255.3.20), 27w6d/stopped, RP 10.239.45.1, flags: SJC
Vlan8, Forward/Sparse, 27w6d/00:02:49
Eigrp prefers the wan link on this switch (port gi /43) to go to site 1. So then on site 1 I connect to switch1 (port gi 1/0/50) (bear in mind my application lives on vlan 50):
sh ip igmp groups
Group Address Interface Uptime Expires Last Reporter Group Accounted
239.255.3.20 Vlan50 18:11:37 00:02:44 10.44.50.24
show ip mroute:
(*, 239.255.3.20), 18:12:40/stopped, RP 10.44.100.100, flags: SP
Not sure how to explain this, any thoughts?
Dan
Does anyone have an idea on this?
Dan
Hi Dan,
Could you please give us a simple drawing of your current Network design and how the Multicast server and recievers are connected?
We could help furhter if we understand more the topology?
Mohamed
I've attached a diagram of the network. Please let me know of any ideas.
Dan
Hi Dan,
1- Before going to any step, could you please clarify why you have 3 different static RPs mapping on your switches? What is the current RP for the group 239.255.3.20 in your topology?
2- from site1 Switch 1 and Switch2 what is the output of (sh ip mroute) & (sh ip igmp snooping group).
Mohamed
I managed to solve the problem. Basically the problem was that Site 1 had a local RP address. But the mutlicast group in Site 2 was bound against Site2's RP.
All I did was add an ACL in Site1 to state that the multicast group that PC's in Vlan 50 in Site 1 want to subscribe to they need to map to the RP address in Site2.
My problem was with my understanding, I thought that different RP's would communicate to inform each other about what multicast group's they have bound to them. Is there a way to set this type of communication up?
Dan
Hello Dan,
I'm glad you got it running.
Regarding your information about the multiple RPs - that's what the MSDP is for. I have seen it in your configuration - I admit I have not checked it thoroughly - but once a RP receives a multicast stream from a source to a particular group, it uses the MSDP to inform the other RP about the existence of this sender and group. The second RP can then send the Join message towards the sender to create a branch of the multicast distribution tree.
However, your network is quite simple. You would be completely fine with a single RP, I believe. Do you have any special need to have two RPs?
Best regards,
Peter
Thanks for info. I do need two RP's for the simple reason that we have developers in Site1 that use multicast for development. If I have one RP in Site2 then Multicast's from site1 will have to traverse the WAN link up to Site 2 RP only for them to be sent back to Site 1.
Is my understanding correct? Am I right in thinking every multicast packet will do the traversing?
Dan
Regarding the traffic flow: A multicast traffic flows from sender to the RP and from the RP to the recipient only if your network insists on using the shared multicast distribution tree. A shared multicast distribution tree is called shared because the part from the RP down to recipients is shared by all flows from all sources to a particular multicast group.
However, the Cisco routers by default do a switchover to a shortest-path multicast distribution tree as soon as they receive the first multicast packet from a particular source. As soon as the first multicast packet traverses from the sender through the RP to the end router onto which the recipient is directly connected, that router will know the sender's IP address. It can therefore send the PIM Join message directly towards the sender, thereby creating a new branch of multicast distribution tree through which the multicast traffic can be sent on the shortest route between the source and the destination. After that, the entire shared branch eventually prunes itself off the RP-rooted multicast distribution tree (unless it is on the shortest path to the source) and what remains is a multicast distribution tree over the shortest path between the multicast sender and the recipient.
Check out this PDF - it's very descriptive:
ftp://ftp-eng.cisco.com/ipmulticast/training/Module5.pdf
So don't worry - your multicast stream should not be going over the RP and back for too long (a couple of milliseconds, a second perhaps, but not longer). By the way, the command that controls the switchover to the shortest-path tree is ip pim spt-threshold 0 where 0 is the threshold in kbps when the switchover should take place - zero means immediately.
Best regards,
Peter
Hi Peter,
Many many thanks for that descriptive reponse. Life is now so much clearer :).
I'll review the pdf plus add points.
Dan
312
