Webcast-Catalyst9k
Help with password of a Catalyst 2800 Switch with no MODE button
I recently got a used Cisco Switch Catalyst 2800 online which does not have a MODE button. It works well. However, the previous owner put a Password on the Management Console and I don't know how to access it. Cisco web site says I should "Contact the Cisco TAC for the factory-installed password". When I called them, I was told Cisco does not support this product any more. Is there a possible way to recover the password? I will appreciate any help you give me.
Eugene
Hall of Fame Super Gold
Re: Help with password of a Catalyst 2800 Switch with no MODE bu
Cisco Catalyst 2800 switch??? Are you sure?
Thanks for your message. Yes, I am pretty sure. On the front panel, it shows:
Catalyst 2800
280285932
Cisco 2802
serial number
I think the middle numbers are serial number.
Eugene
Password Recovery Procedure for the Cisco Catalyst 2800
http://www.cisco.com/en/US/products/hw/switches/ps574/products_password_recovery09186a00800a6c79.shtml
Note: I have never, ever, seen this before. :)
Yes, Catalyst 2800 is an old model. Thanks for your link. I tried with the procedure and actually called Cisco TAC. I was told Cisco cannot give me the factory-installed password because they do not support this model of switch any more. I think it is easy for Cisco to
provide some kind of support, at least allowing users to query the original password. Could you please tell if there is another way to recover
the password?
Thanks again,
Eugene
Catalyst 2800
280285932
Cisco 2802
serial number
Eugene
716
