Community Member
help with remote-access vpn with certificate authentication
hi ,
i need to use remote access vpn with certificate authentication  on router based IOS
how can i make certificate on router and enroll it to the client ?  im confused !
i googled a lot , but coudlnt find a clear view  !
i found something like CA on windows 2008 or 2003 , but i need all be done on router
i dont need to use external CA to my certificate
the question is :
i need to use cisco vpn client so that it works as  "vpn on demand " i believe that  using vpn certificate will achieve my goal .
but i just need a stesp or some one guide me with general steps and i will search for details for them .
i also read about router as CA server..not sure if i need it in my config here !
so , lets summarize ,
i need all be done on router ,
can i use router as CA server and make certificate and enroll the certificate to the vpn and that  router be as remote access vpn certificate ??
any help ?
