Webcast-Catalyst9k
Help with VPN on 1811w
I have attached my config file. I am tring to setup vpn to be used on remote pc and connect to router. I am not sure what I did wrong on the setup. Any and all help would be appreciated.
This is the first step of many I have to embark on, I am taking over from a prior tech that used the gui interface to try and program the router. I have downloaded the basic guide to programming these units and did as much damage control as I could.
Bronze
Re: Help with VPN on 1811w
You can use SDM for configuring thse devices. The software is available for download in the cisco website. With this software the configuration would be much easy.
Can you revert back whether you are able to connect to the router first ?
If yes are you able to get authenticated ?
If authentication is successful are you facing any issues with accessing the internal resources ?
do be clear on what kinda issue you are facing over there in establishing the VPN Access..
regds
161
