Community Member
Hi all Please help me, how can I upload IOS switch3750 on rommon mode,
Hi all my switch3750 is on rommon mode and IOS not found, could anyone help me. URJENTLY
Everyone's tags (1)
Hi Joydev,
You options are either via TFTP:
http://www.cisco.com/en/US/products/hw/routers/ps214/products_tech_note09186a0080110ed1.shtml
...or the slower option, xmodem:
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bfac.shtml
...if using the latter, remember to set your baud speed to something like 115200 to increase the upload speed.
cheers,
Seb.
Community Member
Dear all this process are for router ,Is it success in switch ?
Hall of Fame Super Silver
Yes, the same procedure is used for Catalyst switches that run IOS, including all models of the 3750.
If it's a newer 3750X (or other switch with the USB Type A port) you can use the USB port and upload from a thumb drive (must be FAT16-formatted).
190
