ā11-20-2013 12:00 PM - edited ā03-07-2019 04:42 PM
Hi i need ur helps guys...
I have a problem, 2 switch with ios version c3750e-universalk9-mz.122-58.SE2.bin on stackwise. i cant work with route-map configuration, when i try to write anything command, the switch not accept.
whats version support this features...
Thxs
Julio Mendoza
SW01#sh ver
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 12.2(58)SE2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 21-Jul-11 01:23 by prod_rel_team
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(58r)SE1, RELEASE SOFTWARE (fc1)
SW01 uptime is 6 hours, 10 minutes
System restarted at 07:38:11 Mexico Wed Nov 20 2013
System image file is "flash:/c3750e-universalk9-mz.122-58.SE2/c3750e-universalk9-mz.122-58.SE2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco WS-C3750X-12S (PowerPC405) processor (revision K0) with 524288K bytes of memory.
Processor board ID FDO1727Z1YB
Last reset from power-on
19 Virtual Ethernet interfaces
1 FastEthernet interface
32 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 7C:69:F6:CE:05:80
Motherboard assembly number : 73-13329-05
Motherboard serial number : FDO17271UCC
Model revision number : K0
Motherboard revision number : C0
Model number : WS-C3750X-12S-S
Daughterboard assembly number : 800-32727-03
Daughterboard serial number : FDO17272018
System serial number : FDO1727Z1YB
Top Assembly Part Number : 800-35090-05
Top Assembly Revision Number : E0
Version ID : V04
CLEI Code Number : CMMFG00ARD
Hardware Board Revision Number : 0x05
Switch Ports Model SW Version SW Image
* 1 18 WS-C3750X-12S 12.2(58)SE2 C3750E-UNIVERSALK9-M
2 18 WS-C3750X-12S 12.2(58)SE2 C3750E-UNIVERSALK9-M
Switch 02
Switch Uptime : 6 hours, 10 minutes
Base ethernet MAC Address : 7C:69:F6:CE:13:80
Motherboard serial number : FDO17271UDC
Daughterboard serial number : FDO17272007
System serial number : FDO1727Z1XU
Top assembly part number : 800-35090-05
Top assembly revision number : E0
Version ID : V04
License Level : ipbase
License Type : Permanent
Next reboot licensing Level : ipbase
Configuration register is 0xF
SW01#show license
Index 1 Feature: ipservices
Period left: 8 weeks 4 days
License Type: Evaluation
License State: Active, Not in Use, EULA not accepted
License Priority: None
License Count: Non-Counted
Index 2 Feature: ipbase
Period left: Life time
License State: Active, In Use
License Priority: Medium
ā11-20-2013 12:15 PM
Period left: 8 weeks 4 daysLicense Type: Evaluation
Maybe this is the reason why. Your first switch is running an EVALUATION license of IP Services but your second switch is simply running IP Base. I believe you need to enable IP Services on your second switch.
ā11-20-2013 12:38 PM
When you say route-map do you mean Policy Based Routing ? If so as Leo says you need IP Services for that. In addition you need to be running the routing template on your switches.
"sh sdm prefer" shows which template you are running
"sdm prefer routing" changes to the routing template. You need to reload the switch before it takes effect.
Jon
ā11-20-2013 12:57 PM
is correct i need run PBR with interface vlans
i will check this informatiĆ³n.. and i will share the test
ā11-20-2013 01:10 PM
pls check this it.. i dont know..what i need, for run PBR wirh INTVLAN
i thing the version is the problem.. i need ipservices version...
SW01#show sdm prefer routing
"desktop routing" template:
The selected template optimizes the resources in
the switch to support this level of features for
8 routed interfaces and 1024 VLANs.
number of unicast mac addresses: 3K
number of IPv4 IGMP groups + multicast routes: 1K
number of IPv4 unicast routes: 11K
number of directly-connected IPv4 hosts: 3K
number of indirect IPv4 routes: 8K
number of IPv4 policy based routing aces: 0.5K
number of IPv4/MAC qos aces: 0.5K
number of IPv4/MAC security aces: 1K
thxs
ā11-20-2013 01:28 PM
Can you post output of "sdm prefer ?"
Jon
ā11-20-2013 01:58 PM
its the same
The current template is "desktop default" template.
number of unicast mac addresses: 6K
number of IPv4 unicast routes: 8K
number of directly-connected IPv4 hosts: 6K
number of indirect IPv4 routes: 2K
thxs
ā11-20-2013 02:01 PM
Julio
That's not what i asked you to post. Can you enter the following command and post the output. I just want to check all the templates available -
SW01# sdm prefer ?
Jon
ā11-20-2013 02:03 PM
oki y try write "sdm prefer"
SW01#sdm prefer
% Invalid input detected at '^' marker.
ā11-20-2013 02:10 PM
Did you add the question mark at the end - see previous post.
Jon
ā11-20-2013 02:16 PM
oky sorry u.u i understand bad
check this
SW01#sh sdm prefer ?
access Access bias
default Default bias
dual-ipv4-and-ipv6 Support both IPv4 and IPv6
indirect-ipv4-and-ipv6-routing Supports more V4 and V6 Indirect Routes
routing Unicast bias
vlan VLAN bias
| Output modifiers
ā11-20-2013 02:20 PM
Okay you need to change the template ie.
sdm prefer routing
you need to do this on all switches in the stack. And they will need reloading. But there is no point in doing this until your are running IP Services on all switches.
Once you have all the above you should be able to configure PBR.
Jon
ā11-20-2013 02:27 PM
thxs
whats is the command i need apply on all switches.. it is in configuration mode?
and how i check the template is the correct?
Thxs!
ā11-20-2013 03:10 PM
You need to apply the command on the stack master -
switch# sdm prefer routing
then reload and check with this command -
switch# sh sdm prefer
Jon
ā11-20-2013 05:24 PM
Julio
Just in case you need further info here is the 3750 config guide -
Jon
