Working on a stack of new Catalyst 9200L-24P-4G switches. This is the first time with this model and am beyond frustrated at this point as none of the documentation seems to work. Currently, all 4: Switch Ports Model SW Version SW...
The content you are looking for has been archived. View related content below.
Hi,I have a problem with stacking two cisco 9200L's, after stacking, one of the pair goes straight to privileged exec mode, without enable password, while the other needs password for it. It's not the first time, this occurs, do you have any idea whe...
I get the following error message: https://pastebin.com/WEwAvbsCThe network is shown in the image. I literally just press start all devices, connect to console and get that. I tried googling the error but nothing shows up.
Apr 16 04:14:35.390: %SW_MATM-4-MACFLAP_NOTIF: Host 001b.0907.fe0e in vlan 11 is flapping between port Gi1/1/1 and port Gi1/1/2Apr 16 04:14:35.390: %SW_MATM-4-MACFLAP_NOTIF: Host 001b.0907.fe0e in vlan 11 is flapping between port Gi1/1/1 and port Gi1...
We brought a new core switch (cat 9500) with the intention of shifting to it , however i would like to test some uplink to make sure the link will go up on the shifting day , however I'm worried if i connect the new switch it would mess the vtp or th...
The VLANIF of the core switch acts as the gateway for client. The Client is unable to obtain the gateway IP, but by manually adding ARP, it can communicate with the gateway. The core switch has the correct MAC and ARP information for the client, a...
hello. I understand that Connected routing has an AD value of 0. The IP bands on the 1st and 2nd floors are different. 1st floor: 1.1.1.0/242nd floor: 2.2.2.0/24 There are two firewalls on top of the backbone. The band will be 3.3.3.0/24. If you conf...
Hi Team, Two switches are connected to each and that link is a trunk port between those two switches, The challenge is on one switch when I perform cdp/lldp neigbor detail I can see the other switch which is connected to it but funny thing when I pin...
hi friendsi config below commands to configure AAA authenticate with Microsoft Active Directory 2008(CIsco Device Integrate with AD microsoft for telnet and ssh and both can login to console by AD and local username) but while i unplugged Cisco Devic...
Subject: Seeking Alternative Network Switch RecommendationHi,I hope you're doing well. We've discovered that the SG110D-08 network switch is no longer available. Could you please recommend an alternative that offers similar features and performance? ...
Good day;Need help with how I can configure NAT overload with an existing vrf on a CAT9K_IOSXE V16.12. This is what I am struggling with, I currently have a vrf called AWSDX-S3. Now what I am trying to do is I have added a L2 SW and ran trunk ports...
Hello Community,I am looking a script for switches cisco for block interfaces with APs connected , the reason is because we receive daily port changes and sometimes the engineers change the vlan Wi-Fi by another and the Wi-Fi environment is affected ...
Hi thereI am assigned to check the issues with this attached network and have managed to remove some hups and redesign the network to what it is now. there were no vlans and it has been configured. the issue is that the internet speed is extremely sl...
Does the Catalyst 2960-X or 350-P network switches have internal coin cell batteries to retain memory or clock settings? If so, what is the part number of this battery. Alternatively do you have a safety compliance document for the battery which allo...
I googled this and no answer. What year was it introduced? https://www.ciscopress.com/articles/article.asp?p=2832407&seqNum=5
Subject | Author | Posted |
04-17-2024 03:50 AM | ||
04-15-2024 06:06 PM | ||
04-12-2024 05:48 AM | ||
04-12-2024 01:38 AM | ||
04-06-2024 09:31 AM |
User | Count |
12 | |
10 | |
8 | |
7 | |
7 |
