11-13-2008 01:10 AM - edited 03-06-2019 02:27 AM
I am running MST01 on my network.all the GIG ports are getting connected to leaf switches like 3560 and 4948.when I do the command
"show spanning-tree mst 1 detail" I see that BPDU received on port 3/44 is very high than any other ports .Iam doign this command on the root bridge .
what could be cuasing these BPDU recieve to go high on the root bridge
11-13-2008 01:49 AM
Hello Ajai,
it looks like out that port there is a device that doesn't agree on the root bridge id.
verify the MST region config on the device because if a parameter is mismatching both devices think to be in different regions
OR the device is root bridge for one MST instance
Hope to help
Giuseppe
11-13-2008 02:26 AM
this is the config of MSt on root
spanning-tree mode mst
no spanning-tree optimize bpdu transmission
spanning-tree vlan 1-999 priority 12288
spanning-tree mst configuration
instance 1 vlan 1-999
spanning-tree mst 0-1 priority 8192
The below is the confg for the leaf switch
spanning-tree vlan 1-999 priority 61440
spanning-tree mst 0-1 priority 61440
11-13-2008 12:04 PM
Hello Ajai,
MST configuration includes other parameters that I don't see here.
the region name and the revision number for example have to match.
see
you can also have a look at access switch log with sh log and see if there are STP events
Hope to help
Giuseppe
