Webcast-Catalyst9k
High count of TCN changes
We are facing some high count of tcn changes
 VLAN02312 is executing the rstp compatible Spanning Tree protocol
  Number of topology changes 1895 last change occurred 4d20h ago
          from GigabitEthernet5/5
Gi8./5 is access switch, Pls confirm what are the things needs to be checked to minimize the tcn changes & relevant documentation
br/
Super Bronze
DisclaimerThe Author of this
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Do you use portfast on your edge ports?
Hi, We have already
We have already configured below in Access Port
 spanning-tree portfast
 spanning-tree bpduguard enable
Still tcn count is very high across Network, Pls suggest further how to reduce the same
Br/
HelloUnnecessary TCNs can
Hello
Unnecessary TCNs can also be caused by  ports running in half duplex mode -stp requires point-to-point links to be running full duplex
in rstp these port will negotiate as shared ports
sh interface status
sh spanning-tree | in Sha  (rstp only)
sh spanning-tree vlan xxx | in  Number
Res
Paul
Please don't forget to rate any posts that have been helpful. Thanks.
Hi, We are using RSTP only,
We are using RSTP only, But pls give details of this command/suggestion.
sh spanning-tree | in Sha (rstp only) : Presently no output is showing on switches , Is this expected behaviour
in rstp these port will negotiate as shared ports : How to check that port is shared or not ?
Br/
Hi Subhojit,Could you let us
Hi Subhojit,
Could you let us know what is the end device connected to Gig8/5? Could you configure the command spanning-tree portfast edge on Gi5/5, if the end device connected to it is a work station?
Arun
Hi, Output shared earlier is
Output shared earlier is from Core Switch, 8/5 port is access switch & in the access-switch all host port are configured with below command
Pls suggest further
Br/
264
