High CPU on CE500
We experience high CPU on Cisco 500 switches with average 60 % CPU and found this process running "HULC prs macro p". Does anyone know what this is ?
CE500-LANBASE-M), Version 12.2(25)FY, RELEASE SOFTWARE (fc3
1 ACCEPTED SOLUTION
Hall of Fame Super Bronze
Re: High CPU on CE500
Hi David,
That's related to the smartport service running on the switch. Can you disable ip arp inspection and see if the CPU % decreases?
HTH,
__
Edison.
Hi David,
HTH,
__
Edison.
HI
Thanks for this information, That works fine and the CPU drop to 15%.
402
