High CPU spikes in core switch 6509
durgeshk
Hi All,
We are getting CPU spikes in our both the Core switches 6509 running on HSRP mode.There is no high utilization of traffic in our LAN.
ropethic
Level 4
Level 4
See Link
http://www.cisco.com/en/US/products/sw/iosswrel/ps1828/products_tech_note09186a00800a65d0.shtml
Use the Show Processes
will give you and idea what process is being invoked as well as by task and how long running
srimural
TO add,Check couple of things.
1. if you are running HSRP, check for the stability of the same.
2. If you have spanning tree configured, check what is the version number and if it is increasing rapidly, check for any loops.
3. Any broadcast storms
Attach the o/ps of these commands.
sh process cpu sorted
sh logging
Thanks and Regards,
Srinath Muralidharan
Cable&Wireless
+91 99809 30364
Hi Srinath,
I am so sorry guys for my interupt but I need it.
We are looking to migrate from present LAN to Wireless. Can you suggest me which wireless devices are most advantage and the quotation.
Naidu.
Thats fine. But i need details on what your network is comprising of. If you give me your requirement and drop an email to me. I will get back to you once i am back in office.
Thanks and Regards.
Senior Network Specialist
Cable&Wireless
+91 99809 30364
srinath.muralidharan@cw.com
