08-20-2014 05:39 AM - edited 03-07-2019 08:27 PM
Hi All,
I'm experiencing constant high CPU usage (90%) above on a 3560 switch. I have rebooted the switch. The problem persists. I've had a look at the 'show cpu processes sort' command and I have observed 'FIFO error Detec' is using more than 7% of the CPU.
Has anyone experienced this before? I've never seen the 'FIFO Error Detec'
08-20-2014 02:12 PM
Hey Martin,
When you see there Fifo Error Detection than you have to think that there is something wrong with the queue on one of the interfaces so I suggest looking for that interface. Moroever you mentioned that CPU usage is over 90%, so you may have to check other processes as well.
HTH.
RS.
08-21-2014 09:28 AM
Hi Rajeevsh,
After some more investigation we noticed a lot of multicast traffic from a part of the network. Trying to lock that down now.
