High CPU utilization due to Cat4k Mgmt LoPri in WS-C4507R-E
We are getting the HIGH CPU process due to Cat4k Mgmt Lopri with both core Switches installed at the Customer site.
HTAINHYD03XXXCS0001#sh processes cpu sorted
CPU utilization for five seconds: 89%/2%; one minute: 68%; five minutes: 59%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
52 41015708283160588800 0 68.02% 43.64% 33.26% 0 Cat4k Mgmt LoPri
51 1020058096 667843543 1527 7.83% 11.70% 12.78% 0 Cat4k Mgmt HiPri
111 18148967922560591317 0 7.43% 7.41% 7.42% 0 Spanning Tree
HTAINHYD03XXXCS0002#sh processes cpu sorted
CPU utilization for five seconds: 66%/3%; one minute: 51%; five minutes: 48%
52 3078834762717954896 0 37.51% 20.72% 18.28% 0 Cat4k Mgmt LoPri
51 18107779121821980917 993 8.63% 13.57% 14.40% 0 Cat4k Mgmt HiPri
105 3375271842297524860 0 8.07% 4.48% 3.80% 0 IP Input
111 1901379976 80949735 23488 6.63% 6.75% 6.75% 0 Spanning Tree
223 91174320 296086319 307 1.43% 1.46% 1.45% 0 HSRP Common
Also attaching here the logs show version, show process cpu sorted,show logging, show interface for both the Switches.
Suggest me on this issue facing and confirm if there is any BUG impact or some other specific reason??
Ashutosh
Hall of Fame Super Silver
Re: High CPU utilization due to Cat4k Mgmt LoPri in WS-C4507R-E
Hello Ash,
these processes
Cat4k Mgmt LoPri and Cat4k Mgmt HiPri
are specific of C4500 architecture to further troubleshoot your issue you should read the following specific document:
http://www.cisco.com/en/US/products/hw/switches/ps663/products_tech_note09186a00804cef15.shtml
These processes are actually containers of multiple processes and you need to use
show platform health
to go on in the investigation
Edit:
from the log buffer of the first switch there are some messages that are quite important
068722: May  8 11:47:15.797 IST: %C4K_HWACLMAN-4-ACLHWPROGERR: Input Security: Vlan522-ADWEA - hardware TCAM limit, some packet processing will be software switched.
068723: May  8 11:47:15.797 IST: %C4K_HWACLMAN-4-ACLHWPROGERRREASON: Input(null, 46/Normal) Security: Vlan522-ADWEA - insufficient hardware TCAM masks.
Same kind of messages are reported for other Vlans
CLMAN-4-ACLHWPROGERR: Input Security: Vlan424-Armstrong - hardware TCAM limit, some packet processing will be software switched.
068743: May 14 12:59:41.618 IST: %C4K_HWACLMAN-4-ACLHWPROGERRREASON: Input(null, 16/Normal) Security: Vlan424-Armstrong - insufficient hardware TCAM masks.
CLMAN-4-ACLHWPROGERR: Input Security: Vlan427-Laureate - hardware TCAM limit, some packet processing will be software switched.
068747: May 14 13:01:37.008 IST: %C4K_HWACLMAN-4-ACLHWPROGERRREASON: Input(null, 30/Normal) Security: Vlan427-Laureate - insufficient hardware TCAM masks.
This means that the device is falling back to process switching because the portion of the TCAM table dedicated to implementation of ACLs is full, you should review the ACLs applied to SVI vlan522, vlan 440, vlan 424 and so on  to understand why this happens. This may explain the high cpu usage on the device
on the first device there is also an IP address conflict with an external host
069004: Jun 14 12:37:59.602 IST: %IP-4-DUPADDR: Duplicate address 10.119.81.161 on Vlan525, sourced by 4487.fc8a.2929
OUI search for 4487fc provides the following result:
44-87-FC   (hex)          ELITEGROUP COMPUTER SYSTEM CO., LTD.
4487FC     (base 16)          ELITEGROUP COMPUTER SYSTEM CO., LTD.
                    NO. 239, Sec. 2, Ti Ding Blvd.
                    Taipei  11493
                    TAIWAN, REPUBLIC OF CHINA
Edit2:
the same kind of error appears in the log buffer of the second switch:
069846: Jul  4 16:30:55.682 IST: %C4K_HWACLMAN-4-ACLHWPROGERR: Input Security: Vlan480-Oracle - hardware TCAM limit, some packet processing will be software switched.
069847: Jul  4 16:30:55.682 IST: %C4K_HWACLMAN-4-ACLHWPROGERRREASON: Input(null, 47/Normal) Security: Vlan480-Oracle - insufficient hardware TCAM masks.
Hope to help
Giuseppe
Hello Giuseppe,
Also attaching here the output command sh platform cpu pack stat all, show platform health. Show logging  to investigate this case brief.
Find the attachment for both the Switches.
Ashutosh
Hello Ashutosh,
the issue is with the switch configuration: ACLs or policy maps used for QoS have used all the portion of TCAM dedicated to this purpose, and this causes fall back to process switching in several client vlans with impact on cpu usage
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/53SG/system/messages/emsg.html#wp1253343
Edit:
you may want to open a TAC service request to get further help on this.
Hope to help
Giuseppe
Agree with the reason explaining here for this cause.
Also confirm if some other reason may be found out with the sh platform cpu pack stat all, show platform health. hope that may help us.
Ashutosh
Hello Ashutosh,
as far as I can see in the latest log files there are no other reasons for high cpu usage
Packets Received by Packet Queue
Queue                  Total           5 sec avg 1 min avg 5 min avg 1 hour avg
[output omitted ]
ACL sw processing            650584504      1338      1096       906        785
then you see many items used at 100% related to ACL or QoS
like
Rkios QoS PolicyMaps      356.32       0%            0.03      100%
AclClassifierIdToCla       48.00       0%            0.07      100%
Rkios QoS ClassMaps       896.00       0%            0.16      100%
AclToIosFilterMapLis      384.00       0%            0.07      100%
and
AclOp                    2048.00       0%            0.17      100%
AclOpAceSet              2559.96       0%            3.10      100%
AclClassifier            1280.00       0%            3.71      100%
AclFeature               2570.04       0%            9.35      100%
Acl                      1408.00       0%            4.08      100%
Ace24                    9215.85       3%          287.78      100%
to be noted also some entries related to PIM are at 100%
PimPhyports              1054.68      24%          261.56      100%
PimPorts                  906.25      31%          282.75      100%
PimModules                162.00       1%            3.16      100%
PimSlots                    6.00       2%            0.16      100%
PimChassis                 38.25       6%            2.39      100%
Hope to help
Giuseppe
Hi HCL,
Have you resoved this issue? If so how do you resolved I've the same problem too. :-(
Best regards,
Alcides Miguel
Hello All!!I have the same
Hello All!!
I have the same issue
I attached my files, hope you could help me with some hints about what could be the problem in my case.
Many thanks in advance.
I use "storm-control
I use "storm-control broadcast level 2M" for all interface to find which is a problem interface.
I have enabled a VMWARE
 have enabled a VMWARE servers and these produced the 4500 CPU high.
Reviewing the working modalities found this document delivered to the server administrator.
https://kb.vmware.com/selfservice/microsites/search.do?language=en_US&cmd=displayKC&externalId=2006129
Regards.
35725
