10-31-2013 04:55 AM - edited 03-07-2019 04:21 PM
Hi All,
I'm getting high CPU utilization in Cisco-3750E because of hpm main process. Please share your suggestions for decreasing the same.
SECXI-DC-SWT-DS#sh processes cpu sor
CPU utilization for five seconds: 63%/18%; one minute: 57%; five minutes: 58%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
124 104126484 163508169 636 9.95% 8.56% 8.49% 0 hpm main process
12 11695460 11909185 982 7.06% 6.28% 6.44% 0 ARP Input
231 74992684 24451179 3067 6.26% 6.45% 6.47% 0 Spanning Tree
168 23363773 94354693 247 3.04% 2.24% 2.43% 0 Hulc LED Process
10 7243208 63482 114098 2.08% 0.26% 0.18% 0 Licensing Auto U
220 23404940 9076656 2578 1.92% 1.92% 1.88% 0 ADJ resolve proc
213 4551461 8621761 527 1.76% 1.79% 1.69% 0 IP Input
375 7393 2147 3443 1.60% 0.78% 0.49% 1 SSH Process
128 35630805 3816377 9336 1.28% 1.04% 1.09% 0 hpm counter proc
199 1454235 831191 1749 1.28% 0.18% 0.13% 0 CDP Protocol
85 21241925 13886806 1529 0.80% 0.76% 0.74% 0 RedEarth Tx Mana
91 8292337 327240 25340 0.64% 0.79% 0.79% 0 Adjust Regions
278 1068054 8044622 132 0.32% 0.23% 0.23% 0 DHCPD Receive
169 3156326 2787493 1132 0.16% 0.23% 0.23% 0 HL3U bkgrd proce
264 1266902 5878321 215 0.16% 0.20% 0.24% 0 CEF: IPv4 proces
244 664383 3784626 175 0.16% 0.10% 0.11% 0 PI MATM Aging Pr
84 2452628 18812107 130 0.16% 0.26% 0.26% 0 RedEarth I2C dri
338 198653 33043561 6 0.16% 0.01% 0.00% 0 OBFL VOLT obfl0
107 1356612 110468241 12 0.16% 0.12% 0.15% 0 HLFM address lea
181 1658884 1522165 1089 0.16% 0.06% 0.04% 0 HRPC qos request
180 7796779 761092 10244 0.16% 0.25% 0.25% 0 HQM Stack Proces
57 249691 1097286 227 0.16% 0.04% 0.00% 0 HC Counter Timer
120 255378 253921 1005 0.16% 0.01% 0.00% 0 Strider Tcam Mem
24 27235 3702774 7 0.00% 0.00% 0.00% 0 IPC Deferred Por
23 30113 3702783 8 0.00% 0.00% 0.00% 0 IPC Periodic Tim
26 19155 253923 75 0.00% 0.00% 0.00% 0 IPC Seat Man
AC
10-31-2013 09:31 PM
Hello Athul,
With just this output it's not possible to confirm a high CPU issue on the switch. Can you take another "show processs cpu sorted | exclude 0.00" and a "show process cpu history"?
This can help to determine if a high CPU condition is present.
If you wanna check out what the "hpm main process" works for, maybe a TAC case will be needed (I tried to look for the process but I couldn't find anything about it)
You can also check this link to find out what queue it's receiving more packets on the CPU:
11-01-2013 03:30 AM
Hello Max,
Pls find the outputs
SECXI-DC-SWT-DS#sh processes cpu sor | exc 0.00%
CPU utilization for five seconds: 52%/16%; one minute: 53%; five minutes: 55%
124 112080284 166710608 672 8.95% 8.07% 8.03% 0 hpm main process
231 80885210 26717224 3027 6.23% 6.18% 6.35% 0 Spanning Tree
12 13999986 14350612 975 4.63% 4.62% 4.99% 0 ARP Input
10 7438424 64834 114730 2.07% 0.25% 0.17% 0 Licensing Auto U
168 26026174 96351912 270 1.59% 2.01% 2.28% 0 Hulc LED Process
220 26272102 10308226 2548 1.59% 1.82% 1.82% 0 ADJ resolve proc
199 1573820 872282 1804 1.27% 0.23% 0.14% 0 CDP Protocol
128 36690066 3897701 9413 1.11% 1.10% 1.10% 0 hpm counter proc
213 5194355 9987013 520 0.63% 1.24% 1.32% 0 IP Input
85 21986245 14186714 1549 0.47% 0.71% 0.72% 0 RedEarth Tx Mana
91 9341026 359274 25999 0.47% 0.66% 0.68% 0 Adjust Regions
278 1184233 8280372 143 0.31% 0.15% 0.16% 0 DHCPD Receive
84 2632451 19213259 137 0.31% 0.32% 0.25% 0 RedEarth I2C dri
180 8029088 777251 10330 0.31% 0.22% 0.22% 0 HQM Stack Proces
244 742619 3864818 192 0.15% 0.09% 0.07% 0 PI MATM Aging Pr
SECXI-DC-SWT-DS#sh processes cpu hi
SECXI-DC-SWT-DS#sh processes cpu history
666665555555555666665555555555666664444455555444445555555555
111113333366666222224444466666000009999911111555554444400000
100
90
80
70
60 ***** ********** **********
50 **********************************************************
40 **********************************************************
30 **********************************************************
20 **********************************************************
10 **********************************************************
0....5....1....1....2....2....3....3....4....4....5....5....6
0 5 0 5 0 5 0 5 0 5 0
CPU% per second (last 60 seconds)
666666668777777777778877777777767766777787777777777777777787
859413346491236299750078883679294669622394535413704027040105
100
90 * *
80 * * * ********** *** * * * * * * *
70 *** **************************************************
60 ******#*##################*#######*#####################*#
50 ##########################################################
40 ##########################################################
30 ##########################################################
20 ##########################################################
10 ##########################################################
CPU% per minute (last 60 minutes)
* = maximum CPU% # = average CPU%
899989897799999999998899999999999888998877989898989999899888669888999999
097329697903496770804779526877887030936118268977895898293730962428690888
100 ** * * **** * *** ******* * * * * **** * ** *
90 *** *** ********** ************ *** ************ *** * *****
80 **************************************** ******************* ********
70 **************************#********************##*********************
60 ######**************##########**************##########**************##
50 #########*#######################*####################################
40 ######################################################################
30 ######################################################################
20 ######################################################################
10 ######################################################################
0....5....1....1....2....2....3....3....4....4....5....5....6....6....7..
0 5 0 5 0 5 0 5 0 5 0 5 0
CPU% per hour (last 72 hours)
AC
