High CPU Utilization on 6509 with Sup 720
Please see the following output:
CPU utilization for five seconds: 74.88%
one minute: 76.24%
five minutes: 76.05%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
1 0 2837176798 0 25.12% 23.76% 23.95% -2 Kernel and Idle
12 858748620 2667715367 88000 3.22% 3.92% 3.98% -2 IDLE_Tasks
70 273141953 500021728 487000 1.92% 1.00% 1.00% 0 SptBpduRx
71 633933924 404141420 42000 54.86% 55.84% 55.96% 0 SptBpduTx
91 814921690 2723819046 56000 5.96% 5.92% 5.98% -2 SptFlush
189 786158663 2095789840 348000 4.04% 4.00% 4.00% -2 SlcpProcess
What causes the high SptBPDUtx?
Bronze
Re: High CPU Utilization on 6509 with Sup 720
I think this command will help you : Switch> (enable) show processes cpu
Hi and Thanks for the response, however I got the information from the following command:
sh proc cpu | exc 0.00
Showing only the processes chewing up the CPU.
Again thanks for the response.
Bronze
HI
check this link and hope this is what you are looking for
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a00804916e0.shtml#span
HTH, please rate if it does
rgds
I have read that article, went through the diagnostics and it did not help.... Notice the BPDUrx not the BPDUtx is the concern in the article. Mt BPDU Transmits are high....:-(
Would you be able to try replacing the SUP?
Silver
Is this a box with a lot of linecards, where users with IP Phones are connected?
If so, reconfigure all the ports from TRUNK to "switchport access vlan X" and "switchport voice vlan Y"
This will dramatically reduce your CPU load.
Hall of Fame Super Bronze
It may be doing an excessive Spanning-Tree calculation, an indication of a loop. Do you have multiple switches connected to this device ?
Are these switches interconnected to each other ?
Can you post some kind of network topology ?
Do you see any errors in the switch's log ?
294
