High fabric utilization on a 3560-e
I am looking at the utilization on a Catalyst 3560-E.  I am running a test with eight 1 GIGE links RXing at 95 % utilization.  All of the traffic is going to a TenGigE port.  The device on the TenGigE port is echoing back all of the traffic received, so the 1 GIG links are TXing at 95% as well.
When I do a "show controllers utilization", the port utilization numbers are correct, but the fabric utilization is higher than I would expect.  The fabric should be 128 gigbits / second in this switch, and there is 7.6 gigabits TX/RX to the ten gig port.  The fabric utilization is at 49%.  I would expect 7.6 / 128 = 5.9% or possible double that.  Am I doing the utilization calculation incorrect?
Switch#show controllers utilization
Port       Receive Utilization  Transmit Utilization
Gi0/1              0                    0
Gi0/2              0                    0
Gi0/3              0                    0
Gi0/4              0                    0
Gi0/5              0                    0
Gi0/6              0                    0
Gi0/7              0                    0
Gi0/8              0                    0
Gi0/9              95                   95
Gi0/10             0                    0
Gi0/11             95                   95
Gi0/12             95                   95
Gi0/13             0                    0
Gi0/14             0                    0
Gi0/15             0                    0
Gi0/16             0                    0
Gi0/17             0                    0
Gi0/18             0                    0
Gi0/19             95                   95
Gi0/20             0                    0
Gi0/21             95                   95
Gi0/22             95                   95
Gi0/23             95                   95
Gi0/24             95                   95
Gi0/25             0                    0
Gi0/26             0                    0
Gi0/27             0                    0
Gi0/28             0                    0
Te0/1              76                   76
Te0/2              0                    0
Total Ports : 30
Switch Receive Bandwidth Percentage Utilization  : 49
Switch Transmit Bandwidth Percentage Utilization : 49
Switch Fabric Percentage Utilization : 49
Everyone's tags (3)
Re: High fabric utilization on a 3560-e
Anyone have any ideas on why the fabric utilization is so high?
Tim
Please Tim, send to us the show version or the exact model....
Here is the output from show version, with serial numbers removed.
Cisco IOS Software, C3560E Software (C3560E-UNIVERSAL-M), Version 12.2(52)SE, R)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Fri 25-Sep-09 02:04 by sasyamal
Image text-base: 0x00003000, data-base: 0x02400000
ROM: Bootstrap program is C3560E boot loader
BOOTLDR: C3560E Boot Loader (C3560E-HBOOT-M) Version 12.2(44r)SE3, RELEASE SOFT)
Switch uptime is 3 weeks, 1 day, 22 hours, 24 minutes
System image file is "flash:c3560e-universal-mz.122-52.SE/c3560e-universal-mz.1"
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco WS-C3560E-24TD (PowerPC405) processor (revision G0) with 131072K bytes of.
Processor board ID FDO1424R0CG
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
28 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : XXXXXXXXXX
Motherboard assembly number     : 73-11173-14
Motherboard serial number       : XXXXXXXXX
Model revision number           : G0
Motherboard revision number     : A0
Model number                    : WS-C3560E-24TD-S
Daughterboard assembly number   : 800-29737-01
Daughterboard serial number     : XXXXXXXXXX
System serial number            : XXXXXXXXX
Top Assembly Part Number        : 800-28914-03
Top Assembly Revision Number    : A0
Version ID                      : V04
CLEI Code Number                : COMCA00ARA
Hardware Board Revision Number  : 0x00
Switch Ports Model              SW Version            SW Image
*    1 30    WS-C3560E-24TD     12.2(52)SE            C3560E-UNIVERSAL-M
Configuration register is 0xF
I think strange too..
I used the following calcs:
Total 128 Gbp Full - Duplex
8 Ports x 1Gbp TX
8 Ports x 1gbps RX
1 Port x 10 Gb TX
1 Port x 10 gb RX
36
36/128 = 30%
What about some L3 routing, ACLs, etc
No L3 or ACLs.  Here is my config in case there is somthing strange in it:
Building configuration...
Current configuration : 1977 bytes
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
enable secret 5 XXXXXXXXXXXXXXXX
enable password XXXXXXXXX
no aaa new-model
system mtu routing 1500
authentication mac-move permit
ip subnet-zero
spanning-tree mode pvst
spanning-tree etherchannel guard misconfig
no spanning-tree vlan 1
vlan internal allocation policy ascending
interface FastEthernet0
no ip address
shutdown
interface GigabitEthernet0/1
switchport mode access
switchport nonegotiate
no keepalive
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
no keepalive
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface TenGigabitEthernet0/1
interface TenGigabitEthernet0/2
interface Vlan1
ip address 192.168.175.23 255.255.255.0
ip classless
ip http server
ip sla enable reaction-alerts
no cdp run
line con 0
exec-timeout 0 0
speed 115200
line vty 0 4
password XXXXXXXX
login
line vty 5 15
password XXXXXXXX
login
end
Well over a year later...I am reading this as I am looking at some details within my switches and wondering if this ever got answered?  Tim, if you ever see this....do you remember if this was ever answered?
Respectfully,
No, I never was able to determine why the fabric utilization was so high.
Tim
Well ok.... thank you for the reply.
Chad
962
