High Memory Utilization on Line Card 6748 and 6724
alemunmo81
Hello
I am writing to request help with regard to a high memory utilization that we have on a pair of line card WS-X6748-GE-TX and WS-X6724-SFP for a VSS 6500.
I am enclosing a little part of the "show tech"of this VSS 6500 where is possible to see the high memory utilization of the line cards 1/1, 1/2, 2/1, and 2/2, in despite of having some ports in state connected.  In addition of this, the IOS installed on VSS 6500 is s72033-ipservicesk9_wan-vz.122-33.SXI6.bin for checking if there are some bugs affecting the behaviour of the Switch for this case.
System Resources
  PFC operating mode: PFC3C
  Supervisor redundancy mode: administratively sso, operationally sso
  Switching resources: Sw/Mod    Part number               Series      CEF mode
                        1/1      WS-X6748-GE-TX            CEF720           CEF
                        1/2      WS-X6724-SFP              CEF720           CEF
                        1/3      WS-X6716-10GE             CEF720          dCEF
                        1/5      VS-S720-10G           supervisor           CEF
                        1/6      VS-S720-10G               CEF256          dCEF
                        2/1      WS-X6748-GE-TX            CEF720           CEF
                        2/2      WS-X6724-SFP              CEF720           CEF
                        2/3      WS-X6716-10GE             CEF720          dCEF
                        2/5      VS-S720-10G           supervisor           CEF
                        2/6      VS-S720-10G               CEF256          dCEF
Power Resources switch 1
  Power supply redundancy mode: administratively redundant
                                operationally redundant
  System power: 5772W, 0W (0%) inline, 1725W (30%) total allocated
  Powered devices: 0 total, 0 Class3, 0 Class2, 0 Class1, 0 Class0, 0 Cisco
Power Resources switch 2
Flash/NVRAM Resources
Use: Sw/Mod    Device               Bytes:      Total          Used     %Used
       1/5  RP  bootflash:                    65536000        689820        1%
       1/5  SP  sup-bootdisk:               1024557056     218284032       21%
       1/5  SP  const_nvram:                    129004          2796        2%
       1/5  SP  nvram:                         1964024         49657        3%
       2/5      slavenvram:                    1964024         49657        3%
       2/5      slaveconst_nvram:               129004          2796        2%
       2/5      slavesup-bootdisk:          1024557056     242434048       24%
       2/5      slavebootflash:               65536000         16728        1%
CPU Resources
  CPU utilization: Sw/Mod             5 seconds       1 minute       5 minutes
                    1/1                0% /  1%             0%              0%
                    1/2                0% /  6%             1%              1%
                    1/3                9% /  4%            13%             13%
                    1/5  RP           31% / 25%            14%              5%
                    1/5  SP            7% / 10%             8%              7%
                    1/6  SP            2% /  2%             3%              3%
                    2/1                6% /  5%             1%              1%
                    2/2                2% /  6%             1%              1%
                    2/3                8% /  3%            16%             15%
                    2/5  RP            0% /  3%             0%              0%
                    2/5  SP            6% / 14%             6%              6%
                    2/6  SP            8% /  6%             4%              3%
  Processor memory: Sw/Mod   Bytes:       Total           Used           %Used
                     1/1              268435456      203087872             76%
                     1/2              268435456      203116544             76%
                     1/3             1073741824      243273728             23%
                     1/5  RP         1073741824      405667840             38%
                     1/5  SP         1073741824      480124928             45%
                     1/6  SP         1073741824      295391232             28%
                     2/1              268435456      202461184             75%
                     2/2              268435456      202457088             75%
                     2/3             1073741824      242638848             23%
                     2/5  RP         1073741824      383242240             36%
                     2/5  SP         1073741824      463835136             43%
                     2/6  SP         1073741824      294711296             27%
  I/O memory: Sw/Mod         Bytes:       Total           Used           %Used
               1/1                      8126344        7886544             97%
               1/2                      8126344        7886544             97%
               1/3                     11796240       11442472             97%
               1/5  RP                 12058384       10715832             89%
               1/5  SP                  8388608        8104784             97%
               1/6  SP                  8388608        8104304             97%
               2/1                      8126344        7886544             97%
               2/2                      8126344        7886544             97%
               2/3                     11796240       11442472             97%
               2/5  RP                 12058384       10715832             89%
               2/5  SP                  8388608        8104304             97%
               2/6  SP                  8388608        8104304             97%
I would appreciate any help for overcoming this issue.
AM
Reza Sharifi
Do you have the same problem when there is nothing connected to these modules or only when end devices are connected?
What is the overall CPU utilization?
