High Receive Utilization on VLAN (data)
We use Solarwinds Network Monitoring and noticed that one of our core switches in one building always has a high receive utilization on the main data vlan (20). The switch is a 4503. Is there a way to find out what client or switch is causing this high utilitzation spike? It happens only during working hours. It's always around 75 - 100% throughout the day.
1 ACCEPTED SOLUTION
Bronze
Hi Banseryan, You should be
Hi Banseryan,
You should be able to configure netflow on that switch, this will tell you who the offending senders/receivers are.
I have enclosed a link to the relevant config guide (though this is dependant on having the correct cards in the switch)
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/12-2/20ew/configuration/guide/config/nfswitch.html#wp1022836
Very best wishes
Mike
1 REPLY
Bronze
Hi Banseryan,
Very best wishes
Mike
103
