High received broadcasts on Etherchannel link
Hi Everyone,
We having major network connectivity problems. I'm going to open a case with TAC but thought I would post here first.
I'm seeing a VERY high received broadcast count on 2 our our Cisco 3020 switches. Just wondering if this is normal. The Etherchannel link connects to a 6513.
Have a look below and thanks for any insight u might be able to provide.
Ian.
CHDCBCBSw1#sh int Po1
Port-channel1 is up, line protocol is up (connected)
Hardware is EtherChannel, address is 001d.e60d.8016 (bia 001d.e60d.8016)
Description: Etherchannel Link Core1
MTU 1500 bytes, BW 2000000 Kbit, DLY 10 usec,
reliability 255/255, txload 1/255, rxload 0/255
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, link type is force-up, media type is unknown
input flow-control is off, output flow-control is unsupported
Members in this channel: Gi0/21 Gi0/22
Last input 00:00:00, output 00:00:18, output hang never
Last clearing of "show interface" counters 00:30:50
Queueing strategy: fifo
Output queue: 0/40 (size/max)
8030617 packets input, 3626319105 bytes, 0 no buffer
Received 18446744073695600912 broadcasts (31302 multicasts)
0 watchdog, 31302 multicast, 0 pause input
3414793 packets output, 4086804005 bytes, 0 underruns
CHDCBCBSw1#sh ver
Cisco IOS Software, CBS30X0 Software (CBS30X0-LANBASEK9-M), Version 12.2(40)SE1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Tue 28-Aug-07 18:50 by myl
Image text-base: 0x00003000, data-base: 0x00E80000
ROM: Bootstrap program is CBS30X0 boot loader
BOOTLDR: CBS30X0 Boot Loader (CBS30X0-HBOOT-M) Version 12.2(25r)SEF3, RELEASE SOFTWARE (fc1)
CHDCBCBSw1 uptime is 1 year, 12 weeks, 1 day, 21 hours, 5 minutes
System restarted at 12:51:44 EST Fri Jan 4 2008
System image file is "flash:cbs30x0-lanbasek9-mz.122-40.SE1/cbs30x0-lanbasek9-mz.122-40.SE1.bin"
cisco WS-CBS3020-HPQ (PowerPC405) processor (revision D0) with 118784K/12280K bytes of memory.
Processor board ID FOC1140T0FN
Last reset from power-on
2 Virtual Ethernet interfaces
1 FastEthernet interface
24 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:1D:E6:0D:80:00
Motherboard assembly number : 73-10340-11
Motherboard serial number : FOC11394AUX
Model revision number : D0
Motherboard revision number : C0
Model number : WS-CBS3020-HPQ
System serial number : FOC1140T0FN
Top Assembly Part Number : 800-27541-02
Top Assembly Revision Number : D0
Version ID : V02
CLEI Code Number : IPUIAYGRAC
Hardware Board Revision Number : 0x04
Switch Ports Model SW Version SW Image
* 1 24 WS-CBS3020-HPQ 12.2(40)SE1 CBS30X0-LANBASEK9-M
Hall of Fame Super Silver
Re: High received broadcasts on Etherchannel link
Hello Ian,
this looks an output error
the number of received broadcasts should be less then the total number of received packets
see for example from a TEngiga link of a 4510R-E
1489166305 packets input, 452090226552 bytes, 0 no buffer
Received 114528271 broadcasts (105136510 multicasts)
you see broadcast is less then total packets input
Of course there can be a real issue in the network but the broadcast count looks like unreal (if they follow the usual conventions of Cisco devices)
Hope to help
Giuseppe
Thanks Giuseppe,
Cisco TAC agrees that this must be an IOS bug.
Ian.
1315
