Ho wto clear configuration
dan_track
Quick question, how do I clear the startup configuration?
Dan
5 Replies 5
Amit Singh
Dan,
Switch# erase nvram:
reload
-amit singh
mohammedmahmoud
Level 11
Level 11
You can use "write erase".
HTH ,please do rate all helpful replies,
Mohammed Mahmoud.
ankbhasi
Hi Dan,
If you just want to delete startup config issue
delete nvram:startup-config
if you want to delete all the files in nvram then you can go with any commands already mentioned by other experts.
Ankur
*Pls rate all helpfull post
yeah, on most devices you can either do:
erase nvram
or
erase startup-config
just to add what everyone has said....
if this switch has been part of VTP domain then it will also VLAN.DAT file in the flash:
you should also delete that file (delet flash:vlan.dat)
Shaheen
