Home Agent Redundancy Issue
I am trying to configure a pair of 2911 routers with home agent redundancy and have run into what I think is a routing issue.
When Router 1 is the active HSRP router, the mobile IP bindings are received on the 10.10.40.1 interface and shared to Router 2. I can ping the mobile IP subnet from both routers. Each router has a switch connected to gi 0/0, from the switch connected to Router 1 I can ping the mobile IP subnet, from the switch connected to Router 2 I cannot.
If I make Router 2 the active HSRP by giving it a higher priority the situation is reversed. In that case the switch connected to Router 2 can ping the mobile IP subnet, and the switch connected to Router 1 cannot ping the Mobile IP subnet.
Here is an example of a binding with Router 1 Active.
Router 1
192.168.1.10:
    Care-of Addr 10.10.70.100, Src Addr 172.30.98.102
    Lifetime granted 00:12:30 (750), remaining 00:12:26
    Flags sbdmg-T-, Identification D7AB51B4.530047A3
    Tunnel1 src 10.10.40.1 dest 10.10.70.100 reverse-allowed
    Routing Options - (T)Reverse-tunnel
Router 2
192.168.1.10:
    Care-of Addr 10.10.70.100, Src Addr 10.10.40.2
Router 1
Router 2
IOS
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.1(4)M4, RELEASE SOFTWARE (fc1)
Routing
router eigrp 10
redistribute mobile metric 2 1 255 1 1500
router mobile
router eigrp 10
router mobile
Interface
interface GigabitEthernet0/2
description HSRP connected interface
ip address 10.10.40.2 255.255.255.0
standby 0 ip 10.10.40.1
standby 0 preempt
standby 0 priority 150
standby 0 name mobileStandby
interface GigabitEthernet0/0
description local access subnet
ip address 10.10.50.1 255.255.255.0
ip address 10.10.40.3 255.255.255.0
standby 0 preempt
ip address 10.10.60.1 255.255.255.0
Mobile IP
ip mobile home-agent address 10.10.40.1
ip mobile home-agent redundancy mobileStandby virtual-network address 10.10.40.1 mode active-standby
ip mobile virtual-network 192.168.1.0 255.255.255.0 address 10.10.40.1
ip mobile host 192.168.1.0 192.168.1.254 virtual-network 192.168.1.0 255.255.255.0
ip mobile secure host 192.168.1.0 255.255.255.0 spi D1EA15FC key hex 4d051cd2d14cd658342ed0cb9ef4ab6b algorithm hmac-md5
ip mobile secure home-agent 10.10.40.3 spi 100 key hex 00112233445566778899001122334455 algorithm md5 mode prefix-suffix
ip mobile secure home-agent 10.10.40.2 spi 100 key hex 00112233445566778899001122334455 algorithm md5 mode prefix-suffix
Everyone's tags (1)
24
