host 255.255.255.0
Dear Netpro!
R1#sh ip access-lists
Extended IP access list RIP-OSPF
10 permit ip 199.172.0.0 0.0.255.255 255.255.255.0 0.0.0.255
20 permit ip host 150.100.1.0 host 255.255.255.0
30 permit ip host 150.1.1.0 host 255.255.255.0
question:what this mean ?host 255.255.255.0
many 10xs
1 ACCEPTED SOLUTION
Hall of Fame Super Bronze
Re: host 255.255.255.0
Ali,
That's not a valid host, that should've been part of the subnet mask.
It looks like that ACL is for redistribution and you want to redistribute 199.172.0.0/16, 150.100.1.0/24 and 150.1.1.0/24.
Your ACL you should like this
Standard IP access list RIP-OSPF
10 permit 199.172.0.0, wildcard bits 0.0.255.255
20 permit 150.100.1.0, wildcard bits 0.0.0.255
30 permit 150.1.1.0, wildcard bits 0.0.0.255
___
sh run | sec RIP-OSPF
ip access-list standard RIP-OSPF
permit 199.172.0.0 0.0.255.255
permit 150.100.1.0 0.0.0.255
permit 150.1.1.0 0.0.0.255
__
Remember, with ACLs you must use the inverse mask and use standard instead of extended
HTH,
__
Edison.
Ali,
___
__
HTH,
__
Edison.
10xs edison much appreciated
On the other hand - those could be valid access lists. Access lists of that format can be used to filter BGP routes.
The source portion of the ACL is used to match the network portion of the BGP route and the destination portion of the ACL is used to match the subnet mask of the BGP route.
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a00801310cb.shtml
Filtering Using distribute-list with an Extended Access List
769
