Host Flapping Between Port Channel
I have 2 VSS Pair (4X6509E) Switch. First VSS Pair is configured as Server Core and Second VSS Pair is configured as LAN Core. There is a port channel Port 10 with 4Port configured between Server and LAN Core.  We have also couple Wireless LAN Controllers (5508) Connected to Server Core. PortChannel 25 from Wireless LAN Controller 1 and Portchannel 26 from Wireless LAN  Controller 2. (Only 1 controller will be acitve at a time)
My issue is that am getting a MAC Flapping error between Port Channel 25  and Port Channel 10.  I tried cleard the  MAC entry and from ARP found the IP is LAN Core SVI.
"%MAC_MOVE-SW1_SP-4-NOTIF: Host ec30.91e1.2f80 in vlan 80 is flapping between port Po26 and port Po10"
show arp#
Internet  10.50.200.254          23   ec30.91e1.2f80  ARPA   Vlan50
VLAN 80 is WIreless Guest VLAN.
Please guide me in isolating the issue.
Toplolgy file is attached and also 6509-E is ruuning IOS "s72033-ipservicesk9_wan-mz.122-33.SXI3.bin"
Did you configure the 2 VSS switches in different VSS domains? If not you have to do that. See this link for help.
http://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Campus/VSS30dg/campusVSS_DG/VSS-dg_ch2.html
Mike
its in 2 VSS domain only. VSS domain 200 and 201
I would read through the document and make sure you did not miss anything.
Mike
Hall of Fame Super Gold
Re: Host Flapping Between Port Channel
Please post the interface configuration of the physical and the port channel interfaces (all of it).
The physical interfaces should have "channel-group mode ON".
Load balancing should be "port-channel load-balance src-dst-ip".
SERVER-CORE
interface Port-channel10
switchport
switchport trunk native vlan 50
switchport trunk allowed vlan 2-4094
switchport mode trunk
no mls qos channel-consistency
interface TenGigabitEthernet1/6/1
switchport
channel-protocol pagp
channel-group 10 mode desirable non-silent
nterface TenGigabitEthernet1/6/3
switchport
shutdown
interface TenGigabitEthernet2/6/1
switchport
interface TenGigabitEthernet2/6/3
switchport
interface Port-channel25
description *****Connected to QOC-WLC1*****
switchport
interface GigabitEthernet1/1/3
switchport
channel-group 25 mode on
interface GigabitEthernet1/1/4
switchport
interface Port-channel26
switchport
interface GigabitEthernet2/1/3
switchport
channel-group 26 mode on
interface GigabitEthernet2/1/4
switchport
SERVER-CORE#show etherchannel summary
Group  Port-channel  Protocol    Ports
1      Po1(RU)          -        Te1/5/4(D)     Te1/5/5(P)
2      Po2(RU)          -        Te2/5/4(D)     Te2/5/5(P)
10     Po10(SU)        PAgP      Te1/6/1(P)     Te1/6/3(D)     Te2/6/1(P)     Te2/6/3(P)
25     Po25(SU)         -        Gi1/1/3(P)     Gi1/1/4(P)
26     Po26(SU)         -        Gi2/1/3(P)     Gi2/1/4(P)
1505
