host flapping
jbillingsley
Does anyone know why i'm seeing this constantly is my log:
466682: .Sep 18 15:24:01.113: %SW_MATM-4-MACFLAP_NOTIF: Host a6a6.a6a6.a6a6 in vlan 23 is flapping between port Fa0/12 and port Fa0/24
466683: .Sep 18 15:24:17.102: %SW_MATM-4-MACFLAP_NOTIF: Host a6a6.a6a6.a6a6 in vlan 23 is flapping between port Fa0/12 and port Fa0/24
There are two security cameras plugged into port 12 and 24. It isn't causing any issue, but i want to make sure I'm not ignoring something bigger going on. I've only see this mac in the table on port 24
KMM_IDF3_3560_48_1#sh mac-address-table | i a6a6
23 a6a6.a6a6.a6a6 DYNAMIC Fa0/12
KMM_IDF3_3560_48_1#sh mac-address-table | i Fa0/12
23 0007.181b.52f6 DYNAMIC Fa0/12
KMM_IDF3_3560_48_1#sh mac-address-table | i Fa0/24
23 0007.181a.06ed DYNAMIC Fa0/24
23 a6a6.a6a6.a6a6 DYNAMIC Fa0/24
Thanks for any help
6 Replies 6
jbillingsley
nevermind on only seeing it in port 24. it shows up on port 12 in that last output :-). i do see it jump back and forth in the mac table
Mohamed Sobair
Level 7
Level 7
Whats happing is that STP is frequently turns between Forwardin and blocking state on ports f0/12 and f0/24 for vlan 23 where the host a6a6 reside.
does spanning-tree portfast configured on both ports f0/12 and f0/24?
Pls post relevant switch config?
Mohamed
Hi Mohamed,
Yeah portfast is configured. The thing I can't grasp is that a6a6.a6a6.a6a6 isn't the mac address of either of those devices on the ports. There is no hub in the middle or anything, it's directly connected to cameras.
KMM_IDF3_3560_48_1#sh run int fa 0/12
Building configuration...
Current configuration : 150 bytes
interface FastEthernet0/12
description ** Camara Receiving Dock **
switchport access vlan 23
switchport mode access
end
KMM_IDF3_3560_48_1#sh run int fa 0/24
Current configuration : 151 bytes
interface FastEthernet0/24
description ** Camara North West Rear **
end
KMM_IDF3_3560_48_1#
Mohamed Sobair
Level 7
Level 7
Your config is Ok, I originally thought there is another bridge/hub in the middle with trunk uplinks.
what does the mac a6a6 belongs to? Is it one of the devices attached to the ports?
Mohamed
No, it isn't the mac of one of the devices connected to these ports, that's the weird part. I'm gonna try to reboot that switch or those cameras to see if that gets rid of this.
Hello Jacob,
according to IEEE OUI search page
a6a6a6 is not assigned
http://standards.ieee.org/regauth/oui/index.shtml
so this is a fake address.
Hope to help
Giuseppe
