Host [MAC] vlan [x] is flapping between port [x/x/x] and port [x/x/x]
Hi all, I have two switches connected in cross-3750X stack into a single SW 6500., But I get the following error appears.
18w2d: %SW_MATM-4-MACFLAP_NOTIF: Host 0012.950a.9952 in vlan 10 is flapping between port Gi5/0/46 and port Gi6/0/44
What can i do?
Thank you very much¡¡.
Hall of Fame Super Gold
What is this machine with a
What is this machine with a MAC address of "0012.950a.9952"?  What is the configuration for ports Gi5/0/46 & Gi6/0/44?
This error message is common when etherchannel is not configured properly at either ends.
forget the MAC this is a
forget the MAC this is a example.... on the attahcment you can see the error... yes maybe is a problem with etherchannel.
SW6500-------------SW3750X(1)
            -------------SW3750(2)
is conexion among one 6500 and two 3705X.
when i create the portchannel this issue appear.
Are the two 3750 in a stack?
The configuration on the port
The configuration on the port channel is that all the port must be with the equal configuration :
For example :
interface Port-channel1
 description IDC-TO6500 - 192.168.0.12
 switchport trunk allowed vlan 1,54,136,192,432
 switchport mode trunk
 speed 100
 duplex full
interface GigabitEthernet1/0/1
 speed 100
 duplex full
 channel-protocol lacp
 channel-group 1 mode active
interface GigabitEthernet1/0/2
 speed 100
 duplex full
The same configuration is on the 3750 :
 description IDC-TO3750 - 192.168.0.12
 speed 100
 duplex full
 speed 100
 duplex full
 speed 100
 duplex full
yes, they are.¡
yes, they are.¡
HelloIf you know your
Hello
If you know your physical topology then somewhere between you switches you have a loop
show spanning-tree vlan 10
This will show you what ports are forwarding and its is also where you should discover what port shouldn't be in a forwarding state which is causing the stp loop
res
Paul
Please don't forget to rate any posts that have been helpful. Thanks.
3036
