Community Member
Hot swap redundant sup720 card Catalyst 6513
I have a failed standby 720 sup card that need's to be replaced.  From what I have read, pop out the old and in with the new.  Anyone know of any caveats or documentation regarding this?
Re: Hot swap redundant sup720 card Catalyst 6513
Make sure the replacement is running the same IOS as the active one.
HTH,
jerry
VIP Super Bronze
In addition to Jerry's comment regarding the same IOS, make sure the Sup components i.e PFC is the same as the other one.
In summary, use the same exact hardware and software on both Sups.
Reza
Community Member
Thanks for the answers.
How would I determine what IOS ver it is running before installing it?  My main area of concern is the physicall swap.  I just want to make sure I dont need to do anything on the primary before swapping out the standby.
And yes, the replacement hardware is identical.
You can verify the IOS with a spare chassis (of course, if you have one).
Another way to do it is break it into the ROMMON of the new card after insertion, and force it to boot from the same IOS via an external CF card. There is a risk to do it on the production box, if you are not sure, you should use the spare chassis instead.
HTH,
jerry
Community Member
I replaced failed sup card and it booted up with the latest IOS from Cisco, .33 something.  It then synced over the config file from the primary.  However, it never synced the older IOS image we are running on the primary.  So I reloaded the switch and when it booted back up it booted off of our older IOS code.  No other issues.
One note:  While they were running different IOS version, redundancy mode was rpr but when I synced teh IOS's the mode is now SSO and the standby is HOT instead of COLD.
1956
