Community Member
How can I find out which services are running?
Is there a command I run on any router on switch that will show me a total list of what services I have running e.g. dhcp, finger, http etc..
Dan
1 ACCEPTED SOLUTION
Re: How can I find out which services are running?
HI Dan, [Pls RATE if HELPS]
Below provided the Command:
Router#sh processes cpu ?
history Show CPU history in graph format
sorted Show sorted output based on percentage of utilization
| Output modifiers
Hope I am Informative.
Pls RATE if HELPS
Best Regards,
Guru Prasad R
| Output modifiers
Pls RATE if HELPS
Best Regards,
Guru Prasad R
Check out this command too, show ip sockets.
211
