How can i see the posts that i answered?
chandra_rc16
Level 4
Level 4
Actually i some others post for a VLAN.. now i need that post ... but i'm unable to find it...
Can someone please help me in this ?
Chandu
Regards, Chandu
Richard Burts
I probably do not fully understand your question. Based on what I think I understand I offer these suggestions:
- if you click on your profile, or using the account link on a forum page select profile, then at the bottom of the information of your profile is a list of the responses that you have made. But it displays a limited number of responses.
- if you use the search feature of the community you might find it by searching on your name, or better to search for some term that was used in the response.
Rick
Rick
Richard Burts
Rick
Rick
The above line helped me to get over there.
Thanks a lot.
Regards, Chandu
Chandu
I am glad that my suggestion was helpful. Thank you for using the rating system to mark this question as answered. I look forward to seeing more posts from you in the forum.
Rick
Rick
