Community Member
How can i verify the Serial number of GBIC
Hi All,
May i know the command to verify the serial number of GBIC?
Thank you,
Purple
Re: How can i verify the Serial number of GBIC
"show idprom interface gx/x " should give you that . This is on newer switches like 4500's and 6500's ,3650's etc...
Community Member
I use 3548-xl-en Switch. The show idprom is not listed? Can you please give me right command to check in the 3548 Switch.
Hall of Fame Super Silver
Hello Sivaprakasam,
your switch may support
sh inventory
this tells the s/n
Hope to help
Giuseppe
I have never been able to find the command for stackables, but for chassis switches try-
show idprom interface gigabitEthernet [port number]
Hope that helps.
Hall of Fame Super Gold
The WS-C3500-XL-EN does not have the support to "interrogate" the GBIC for details such as S/N. You have no choice but to pull it out.
203
