How can we set 2950 swtich IOS to be loaded from TFTP
Hi All,
2950 switch has a IOS on flash , but i would like to set the swith like...
1. switch IOS to be loaded from TFTP server .if it fails
2. Loaded from local flash IOS1 , if it fails
3. IOS loaded from local flash IOS2.
Please suggest, does 2950 switch support this feature.
Thanks in Adv
Sri
Hi All,
I have gone through some cisco links and found we can NOT set 2950 switches to be loaded from TFTP server . However we can set multiple IOS images by using ";"
#config t
#boot system flash:
   c2950-i6q4l2-mz.121-13.EA1.bin;c2950-i6q4l2-mz.121-12c.EA1.bin
Please post your thoughts.
Sri
Dear Sri,
                    Yes u r right u can use multiple images in ur flash but also depends if they all r having the same feature set and also the size of the flash matters a lot, and you can use tftp server to load IOS, if it's in d same vlan you wont be facing any issues, see that udp/69 is open and u can use the following command to work
boot-start-marker
boot system tftp <image name> <ip address>
boot system flash
boot-end-marker
Krishna
537
